3930 clutch issues
Goto page 1, 2  Next
Texczech
PostPosted: Tue Jan 14, 2020 8:39 am    Post subject: 3930 clutch issues Reply to specific post Reply with quote
I have a 3930 that is hard to get into gear. It has a 7209 loader on it.It has a 4 speed with L-H stick also. Any tips on getting the loader off, and any advice on clutch removal & replacement? As well as other things to check while the tractor is split? Thanks for any information!
Destroked 450
PostPosted: Tue Jan 14, 2020 12:07 pm    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
Have you tried adjusting the clutch?
How much free travel does the pedal have.
List the unit number, model number and serial number off the side of the trans or from the data tag under the hood.
3930 went through a number of changes during it's production run, need to know which one you have.
What loader does it have?
Can you post a photo of the tractor and loader.
Texczech
PostPosted: Wed Jan 15, 2020 10:34 am    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
3C03B DA70K07 are the numbers on the block flat area
Sean in PA
PostPosted: Wed Jan 15, 2020 10:50 am    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
Texczech wrote:
(quoted from post at 14:34:47 01/15/20) 3C03B DA70K07 are the numbers on the block flat area
He was asking for the numbers on the flat spot on the transmission bell housing above the two large bolt holes, just above and toward the rear of the tractor from the starter, or the numbers from the sticker on the under side of the right hood panel, above the battery.
Texczech
PostPosted: Thu Jan 16, 2020 10:20 am    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
Under hood info Tractor Number BD41857 Model Ca514C Unit 3C15B Trans,Rear Axle, Hyd Pump=3C08B Hyd Lift 3C12A
Destroked 450
PostPosted: Thu Jan 16, 2020 12:35 pm    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
Model # CA514C
CA5 = 3930 all purpose
1 = Diesel engine
4 = Ind 540 PTO
C = 8x2 manual trans
Production date 3C15B
Tractor was built March 15, 1993 on day shift
Serial # BD41857 is for a tractor built in 1993
You tractor has the standard 8 spd trans Ford has used since 1965, it gives very little trouble and normally shifts with ease.
Hard shifting is normally from being low on oil or the clutch is dragging (no completely disengaging), this can be from worn pressure plate release fingers or improper linkage adjustment.
After checking oil level linkage adjustment is the next thing to check, you should be able the easily push the pedal down 1 - 1 1/2" before feeling much resistance, much over 2" of free travel will require linkage adjustment.
Check this first and let us know what you have.
Texczech
PostPosted: Sat Jan 18, 2020 5:26 am    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
I do have the clutch adjusted with freeplay. I am assuming there is a pressure plate or pilot bearing issue. I am going to split the tractor, any tips or advice on doing this job?Thanks!
Destroked 450
PostPosted: Sat Jan 18, 2020 8:06 am    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
Normally splitting a Ford tractor isn't a big job but on the later models like yours they made some changes that really complicated the job.
First the loader has to come off, I'm not familiar with the loader you have has to weather it's a quick attach model or not, regardless the loader and any subframe that attaches the front axle to the transmission and or rear axle must be removed.
Hopefully you have a concrete floor to work on in order to roll the tractor apart.
The plastic fuel tank and much more complicated wiring harness makes splitting your tractor a lot harder than a early model.
If you don't have it I recommend you purchase a I&T Manual # FO-47.
I'd like a little more info on what the tractor is doing other than hard to get in gear.
Is this something that's started recently?
Does it grind going in gear or are the shifters hard to move?
In gear with the pedal down does the tractor continue to pull itself?
With the pedal down once stopped will the shifters easily slide out of gear or are they difficult to move like the clutch is dragging?
Does any oil leak from the weep hole under the clutch housing?
JoeM(GA)
PostPosted: Sat Jan 18, 2020 10:08 am    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
Tex, I have a PDF of the Ford 10/30 series service manual, it's a huge file,
but can share a link to it with you if wanted. Shoot me your email if wanted
Joe
Destroked 450
PostPosted: Sat Jan 18, 2020 12:36 pm    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
First or second edition?
I have the first edition 10-30 series manuals and there's very little in them about the later model 3930,4630 tractors and nothing about the 5030.
JoeM(GA)
PostPosted: Sat Jan 18, 2020 2:02 pm    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
it's dated 11/95 doesn't say second edition so I'd assume that it would be a first addition
Destroked 450
PostPosted: Sat Jan 18, 2020 5:09 pm    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
Mine doesn't have a edition number but it's the 6 volume set, later they came out with a 7 volume set splitting the electrical into 2 volumes, not sure if any other info is different or not.
There is a separate set of manuals that serve the later 3230, 3930, 4630 and 5030 models, these are probably the ones he needs but the I&T manual I recommended should help him at a lower cost.
Texczech
PostPosted: Mon Jan 20, 2020 5:28 am    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
It does grind when going into gear.The tractor will pull itself somewhat when the clutch pedal is down. The shifters are hard to move with the pedal down. I can't tell if there is much oil underneath, it is a little messy. Thanks for the reply!
JoeM(GA)
PostPosted: Mon Jan 20, 2020 1:33 pm    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
Texczech wrote:
(quoted from post at 17:39:45 01/14/20) I have a 3930 that is hard to get into gear. It has a 7209 loader on it.It has a 4 speed with L-H stick also. Any tips on getting the loader off, and any advice on clutch removal & replacement? As well as other things to check while the tractor is split? Thanks for any information!
Hey Don, the email in your YT message comes back as no good,
Check and message me
Destroked 450
PostPosted: Mon Jan 20, 2020 9:17 pm    Post subject: Re: 3930 clutch issues Reply to specific post Reply with quote
Got the download, thanks
It's better than my books but still doesn't show much on the later 30 series.
Goto page 1, 2  Next
Page 1 of 2
