white drawbar
spitz
PostPosted: Tue Jan 14, 2020 10:40 am    Post subject: white drawbar Reply to specific post Reply with quote
Hey guys, I recently picked up a 20? Krause no till drill with what I call an eyeball type hitch on it. My white 120 has the straight drawbar with only one hole. I am not sure How or if I can get a hammer strap on this drawbar? Does anyone know where I can get a clevis type hitch for a 100 series white? What other white drawbars will fit the 120? Does anyone make a hammerstrap for these? I have checked local (mn) salvage yards and the white dealer. No luck. Does anyone have a three point adapter for the Krause drill? As always any advise, ideas, etc is always welcomed!
Wisconsin Cowman
PostPosted: Tue Jan 14, 2020 2:30 pm    Post subject: Re: white drawbar Reply to specific post Reply with quote
Is it possible to change the drill hitch to a clevis hitch?
Should be fairly easy to make a hammer strap. Heavy peice of flat steel and some type of spacer and two bolts through the drawbar.
Wisconsin Cowman
PostPosted: Tue Jan 14, 2020 2:49 pm    Post subject: Re: white drawbar Reply to specific post Reply with quote
Agco part number for hammer strap drawbar 72160810.
Some other tractors that use the same drawbar.
Allis 9100 series tractors
Agco 9630,9650,9670,9690,9675,9695.
72160810 subs to different numbers
72515547 drawbar
3618567M1 clevis
70950102 hex bolt M20x2.5
oliverplow
PostPosted: Tue Jan 14, 2020 5:25 pm    Post subject: Re: white drawbar Reply to specific post Reply with quote
I guess I have never seen a White tractor with a straight drawbar, and yes, I own five of them. All of mine are curved so they can be flipped for which ever height you want. All have a hole for hammer strap bolt. I'm pretty sure the drawbar on my 100s are the same as my 135, but I've never pulled them out to check. I would suggest checking Wisconsin salvage yards for correct drawbar.
spitz
PostPosted: Tue Jan 14, 2020 6:04 pm    Post subject: Re: white drawbar Reply to specific post Reply with quote
The problem isn't the height its the need for a clevis type hitch. The one I have only has one bolt to hold down a hammerstrap. Won't the strap break a single bolt off? The leverage of that hitch seems to me would break that bolt. Is there any Wisconsin salvage yard you would recommend? I saw a 6125 drawbar that has two hammerstrap bolt holes. Will these fit the 100 series?
spitz
PostPosted: Tue Jan 14, 2020 6:07 pm    Post subject: Re: white drawbar Reply to specific post Reply with quote
Thanks for the list of other tractors so I can expand my search! Dealer sounded like the clevis hitch was no longer available but I think my parts book had a different part number. Thanks again!
oliverplow
PostPosted: Tue Jan 14, 2020 8:09 pm    Post subject: Re: white drawbar Reply to specific post Reply with quote
Try Heitman tractor salvage in Durand, WI.
hrRoss
PostPosted: Tue Jan 14, 2020 9:11 pm    Post subject: Re: white drawbar Reply to specific post Reply with quote
i have hammerstraps on my 4-150 and 4-210, the 4-270 has it welded onto drawbar. I remember getting one at wis tractor parts, blackcreek, several years back. 4-150, and 4-210 are the same. maybe change drawbar?
