cub transmission oops?
4936farmall
PostPosted: Tue Jan 14, 2020 7:32 pm    Post subject: cub transmission oops? Reply to specific post Reply with quote
I asked this question on another forum and got 1 response which i'm leaning towards being correct. I am not trying to offend anyone by not instantly taking ones word for it but re-splitting a tractor is a pain and would like more verification before I do so. When replacing the transmission input shaft in my cub I found the front bearing to be sealed on one side and installed with the seal facing the trans. I would have thought the seal would be away from the oil side so I reversed the bearing on the new shaft, which is apparently incorrect. My question is will there still be enough splash lube to oil the bearing or will I in-fact have to go back in and change the bearing orientation?
Janicholson
PostPosted: Wed Jan 15, 2020 10:48 am    Post subject: Re: cub transmission oops? Reply to specific post Reply with quote
I think you are good to go. Jim
khouse6
PostPosted: Wed Jan 15, 2020 2:50 pm    Post subject: Re: cub transmission oops? Reply to specific post Reply with quote
seems to me that reversing this bearing will allow shaft to move forwards slightly, therefore, the pto shaft will not engage, properly, after a period of time.
dale shaw, on farmall cub rescue, can tell you more. or correct my reply.
John M
PostPosted: Wed Jan 15, 2020 6:35 pm    Post subject: Re: cub transmission oops? Reply to specific post Reply with quote
Not the right bearing. The right bearing does not have a seal on it at all. If oil cant get through the bearing, the oil seal will burn up because it isn't getting the lube it needs as well.
Janicholson
PostPosted: Thu Jan 16, 2020 7:22 am    Post subject: Re: cub transmission oops? Reply to specific post Reply with quote
I stand corrected, The bearing should be without seals either side. The real seal will fail with no lube. Packing the space between the bearing and correct seal shown in the parts catalog would work in the same way putting two seals on a shaft at other locations works. One could also remove the seal from the bearing. Jim
Bob
PostPosted: Thu Jan 16, 2020 8:37 am    Post subject: Re: cub transmission oops? Reply to specific post Reply with quote
CVPost-Janicholson wrote:
(quoted from post at 10:22:44 01/16/20) I stand corrected, The bearing should be without seals either side. The real seal will fail with no lube. Packing the space between the bearing and correct seal shown in the parts catalog would work in the same way putting two seals on a shaft at other locations works. One could also remove the seal from the bearing. Jim
It's POSSIBLE the O.P.'s bearing has a "SHEILD", rather than an actual "seal".
That's COMMON with transmission bearings.
https://www.bearingtips.com/difference-bearing-shields-bearing-seals/
