Air tank
MF294-4
PostPosted: Sun Jan 05, 2020 7:34 am    Post subject: Air tank Reply to specific post Reply with quote
Got two good portable air compressors with bad tanks. they are fairly old (20-30 yrs)but old is good. Pumps and motors that is. Both are craftsman. Does anyone replace tanks? Where do you find a reasonable priced one? Just spent hours on the internet looking with no success.
Oregon Tractor Jack
PostPosted: Sun Jan 05, 2020 8:07 am    Post subject: Re: Air tank Reply to specific post Reply with quote
I had a tank on an up right compressor go bad. The compressor was still good of course. I did what you did and looked for a replacement tank. No luck. I found tanks, but by the time you buy the tank and have it shipped you have the price of a new compressor. Plus you cannot be sure the mounting on the new tank would work with the compressor and motor you have. If you just needed to drill a few holes in a mount to make it work great. The real problem would be if you needed to weld a mount on to the new tank. You should never, ever weld on a pressure vessel unless you are a certified welder with a pressure vessel cert.
OTJ
Russ from MN
PostPosted: Sun Jan 05, 2020 8:10 am    Post subject: Re: Air tank Reply to specific post Reply with quote
I was able to get some good used steel propane fork truck tanks when my place of work switched to aluminum, they're about 10 gallons, perfect for what I wanted.
Mike(NEOhio)
PostPosted: Sun Jan 05, 2020 9:28 am    Post subject: Re: Air tank Reply to specific post Reply with quote
I have one too. You can buy receivers from a lot of sources but unless you can find a good one (emphasis on good) cheap you can get a whole new unit for less money.
matthies
PostPosted: Sun Jan 05, 2020 2:36 pm    Post subject: Re: Air tank Reply to specific post Reply with quote
Surpluscenter.com
Geo-TH,In
PostPosted: Sun Jan 05, 2020 5:08 pm    Post subject: Re: Air tank Reply to specific post Reply with quote
I got a portable 8 gallon, 1.5 hp oil compressor at HF for $100 on sale.
To make a compressor truly portable. You need to find a smaller one that a generator can power. I purchased a 0.6 hp compressor with brushes for around $100. Very slow. Very quiet. Can't hear it running next to generator. I added a second tank form a air compressor that the pump went bad. I can run a air framing nailer off it. Sometimes I have to wait a few seconds for it to catch up. But it's portable air I can carry around in back of truck.
geo
Dusty MI
PostPosted: Sun Jan 05, 2020 7:30 pm    Post subject: Re: Air tank Reply to specific post Reply with quote
Back in the early '60's I bought a portable air tank. You fill the tank and then take it with you. I would think you could use it for a tank for a compressor.
Jack345
PostPosted: Sun Jan 05, 2020 8:00 pm    Post subject: Re: Air tank Reply to specific post Reply with quote
Russ From MN. That is a super tank & great job. Thanks for picture.
urbancase
PostPosted: Mon Jan 06, 2020 2:58 am    Post subject: Re: Air tank Reply to specific post Reply with quote
look on the net and goggle McMaster-Carr, they sell all kinds of tanks.
sms
PostPosted: Mon Jan 06, 2020 4:37 am    Post subject: Re: Air tank Reply to specific post Reply with quote
You should be able to look up parts for your compressor and find the exact tank but it may not be cost effective.
Stephen Newell
PostPosted: Sun Jan 12, 2020 3:56 pm    Post subject: Re: Air tank Reply to specific post Reply with quote
There are places such as grainger that sell replacement tanks. Grainger is high priced though.
OregonAaron
PostPosted: Wed Jan 15, 2020 8:51 am    Post subject: Re: Air tank Reply to specific post Reply with quote
Seems to me usually the motor/compressor goes bad before the tank- the reason I say this is that at our local scrap metal yard there are always lots of old compressors with great tanks in the pile. Throw away mentality society. However a guy might be able to buy one for scrap price. Lawnmowers too, tons of them... probably just need a carb clean as most are fairly new!
