Super C rear engine seal
Charlie M
PostPosted: Fri Jan 17, 2020 11:36 am    Post subject: Super C rear engine seal Reply to specific post Reply with quote
When spring gets here I need to split my Super C and replace the clutch. I'm also going to replace the rear oil seal while I have everything apart. Question is do I have to remove the oil pan to get the seal
retainer off? Seems like I remember on my H there is a screw hidden by the oil pan.
Red Dave
PostPosted: Fri Jan 17, 2020 1:58 pm    Post subject: Re: Super C rear engine seal Reply to specific post Reply with quote
The answer is Yes.
I know it is Yes on an A or B, and the Super C is the same basic engine.
bass
PostPosted: Mon Jan 20, 2020 2:36 am    Post subject: Re: Super C rear engine seal Reply to specific post Reply with quote
while you have the tractor split, check the freeze plugs on the back side of the block. there are two and their the disk type, not the cup type. one of mine had a pin hole, put jb weld on it and its still holding.
bass
Bob
PostPosted: Mon Jan 20, 2020 4:19 am    Post subject: Re: Super C rear engine seal Reply to specific post Reply with quote
bass wrote:
(quoted from post at 05:36:33 01/20/20)
bass
You "puckied" the rusted-out plug rather than replacing it???
Plug is 2", Dorman #550-028, available for a buck or two at about any auto parts store.
Stealership wants over $20, though! How is that even possible?
Ken Hansen
PostPosted: Mon Jan 20, 2020 4:38 pm    Post subject: Re: Super C rear engine seal Reply to specific post Reply with quote
Bob wrote:
(quoted from post at 08:19:11 01/20/20)
bass
Considering the work needed to access those plugs and the damage to the engine if one failed at the wrong time with wrong operator running it I would use one of the "factory $20.00" plugs before trying to patch one.
Figure the original one may be over sixty years old so who here is going to be around to worry about replacing the new one put in this year?
Besides if the coolant is changed even every ten years the plug put in this week will probably be still good at the turn of the next century!
bass
PostPosted: Tue Jan 21, 2020 5:39 pm    Post subject: Re: Super C rear engine seal Reply to specific post Reply with quote
don't know where your at, but around here there unheard of. I have to order them. guess its an East Texas thing.
bass
Ken Hansen
PostPosted: Wed Jan 22, 2020 6:24 am    Post subject: Re: Super C rear engine seal Reply to specific post Reply with quote
bass wrote:
(quoted from post at 21:39:56 01/21/20)
bass
Find it hard to believe that the NAPA dealer in Henderson does not stock them or at the worst can not get them overnight! But then maybe I'm just lucky to have a couple good NAPA dealers near me.
Heck I got all the parts right down to a new coil to rebuild the magneto of my BN last summer and only had to wait for the truck from warehouse to drop the coil off afternoon on the day I called the order in!
bass
PostPosted: Wed Jan 22, 2020 2:32 pm    Post subject: Re: Super C rear engine seal Reply to specific post Reply with quote
[quote="Ken Hansen"](reply to post at 07:24:03 01/22/20) [/the local napa dealer would not order parts for tractors.... maybe that's why we don't have a napa dealer any more in Henderson
bass
Ken Hansen
PostPosted: Wed Jan 22, 2020 5:22 pm    Post subject: Re: Super C rear engine seal Reply to specific post Reply with quote
[quote="bass"](quoted from post at 18:32:16 01/22/20)
bass
Are there no other automotive stores in or near Henderson?
bass
PostPosted: Thu Jan 23, 2020 12:04 pm    Post subject: Re: Super C rear engine seal Reply to specific post Reply with quote
yep there are three other parts stores, none have disk freeze plugs...ive checked
bass
