Flash the Field?
Goto page Previous  1, 2
Phil (NJ,Az,Sask)
PostPosted: Thu Jun 07, 2007 11:17 am    Post subject: Re: NO! Reply to specific post Reply with quote
Dan,
Bob is correct! Both the A & B type have the
field circuit NC (normally connected).
The A Type Field Terminal is (NC) connected to "Ground" via both the current & voltage Relays.
The B Type field Terminal is (NC) connected to the Armature Terminal via both the Current & Voltage Relays.
This regulation method is one of the bad features of a Generator. The Generator has residual(uncontrollable)Magnetism and must be Turned-off (regulated) by "reducing" the field current. Its akin to controlling the speed of your Car using the brakes, with the Gas Pedal floored.
Most PLL know better then to Short the +ve (Pos)& -ve (neg) posts of a battery but they don't consider that when the wires or contacts are smaller. The Smaller wires or relay contacts have near the "SAME" potential, as the Battery Posts, and will try to supply the >150 amps but will self destruct.
This is why PLL that play with the regulator Field Terminal damage the Regulator &/or the wiring.
JMHO
dan hill
PostPosted: Fri Jun 08, 2007 3:12 am    Post subject: Re: Flash the Field? Reply to specific post Reply with quote
Time for the polarize turkeys to fly away.The polarize bit has cooked many parts.No returns on electrical parts sign in parts store says it all.
Page 2 of 2
