Is my governor right?
dsebens
PostPosted: Tue Feb 25, 2020 5:08 am    Post subject: Is my governor right? Reply to specific post Reply with quote
On my 73 3400 if I slowly bring my idle down it will idle at 1000-1100 according to the proof meter. If I give the throttle a blip or drop the rpm's quickly it will drop down to 650-800ish(I can't remember what exactly)
My linkage is free, is this a normal operation or do you have any ideas. It doesn't bother me too much since a blip can drop it down but was just curious.
Mike(NEOhio)
PostPosted: Tue Feb 25, 2020 5:37 am    Post subject: Re: Is my governor right? Reply to specific post Reply with quote
My 2000 does the same thing. I never could get the linkage quite right. I think the problem is when the rod is set to the correct length there is a bit of free play between the bell crank and the plug inside the spring. If I adjust that out it acts differently. It's been a while since I played with it so I can't remember which way it worked but sometimes it would not hold the throttle at PTO speed under load.
graham_in_NJ
PostPosted: Tue Feb 25, 2020 5:55 am    Post subject: Re: Is my governor right? Reply to specific post Reply with quote
I think it's more of a carb adjustment issue. If you're "blipping" the throttle, you may just have either a lean or rich condition causing the slow down and the reaction of the governor may be accurate, but with too much/too little fuel, you won't get the response you're expecting.
Do you get a puff of black smoke when you rev it?
dsebens
PostPosted: Tue Feb 25, 2020 6:22 am    Post subject: Re: Is my governor right? Reply to specific post Reply with quote
Tractor runs good. When I blip the throttle it will stay at idle until I speed it up again
