transmission problems need help
DEERHUNTER1
PostPosted: Sat Jun 09, 2007 12:23 pm    Post subject: transmission problems need help Reply to specific post Reply with quote
my tractor is broke down in a bad spot guys,was brushhoggin the back part of our property and it just stopped while turning.it still runs but it is stuck in first gear and won't move. any help so i can atleast get it up here by the house.took the shifter out but don't know what to look for in there.i at least need to be able to move it if i leave it where its at i have a bad feeling things will disappear off it.
DEERHUNTER1
PostPosted: Sat Jun 09, 2007 1:42 pm    Post subject: Re: transmission problems need help Reply to specific post Reply with quote
heres a picture
Dunk
PostPosted: Sat Jun 09, 2007 2:04 pm    Post subject: Re: transmission problems need help Reply to specific post Reply with quote
Does it just bog the engine down when you let out the clutch the way it is?
Disengage the PTO and see if it will move then.
If you can't get the PTO disengaged, take the PTO shaft off.
DEERHUNTER1
PostPosted: Sat Jun 09, 2007 2:23 pm    Post subject: Re: transmission problems need help Reply to specific post Reply with quote
it bogs the engine down, the pto is disengaged. it also won't tow with the clutch pushed in
Dunk
PostPosted: Sat Jun 09, 2007 2:53 pm    Post subject: Re: transmission problems need help Reply to specific post Reply with quote
Then your tranny is in 2 gears at the same time.
You have to move the gears and get it out of at least one of those.
I don't know how to tell you how to do that other than to fiddle with slipping the gears in and out.
Another guy had the same problem lately, and never did figure out how to get one of them to come out, and last I heard he was going to break the tractor in half.
I think it can be gotten out of it by fiddling with it.
I think I have done it before, a long time ago.
DEERHUNTER1
PostPosted: Sat Jun 09, 2007 3:12 pm    Post subject: Re: transmission problems need help Reply to specific post Reply with quote
i gotta get it up to the house somehow
Dunk
PostPosted: Sat Jun 09, 2007 3:28 pm    Post subject: Re: transmission problems need help Reply to specific post Reply with quote
If it's not the tranny hung up in 2 gears, then something happened in the rear end.
But with the PTO disengaged, and it seeming hung in 1st, I thave to think it is in 2 gears at once.
ZANE
PostPosted: Sat Jun 09, 2007 3:30 pm    Post subject: Re: transmission problems need help Reply to specific post Reply with quote
It's hung up in two gears at the same time. You can tell because the three shifters are all in a different position. All three must be together to be in neutral.
Do not pry on the shifters. They can be bent pretty easy. Try to pry the big gear at the back of the transmission forward. That is first gear and the easiest to move usually.
It might help to jack up one wheel ahd have somebody shake it back and forth while you pry on the big gear toward the front or have somebody pry while you shake it with another vehicle.
Don't get run over!!!!
Zane
Zande
ZANE
PostPosted: Sat Jun 09, 2007 3:34 pm    Post subject: Re: transmission problems need help Reply to specific post Reply with quote
That sliding coupling that you can see toward the back of the transmission is slid back to engage first gear and it will have to be in the center of the two coupling splines to be in neutral. Once it is in neutral the other one will be easy to move to neutral.
Zane
old9
PostPosted: Sat Jun 09, 2007 5:15 pm    Post subject: Re: transmission problems need help Reply to specific post Reply with quote
Hope your luck is better tham mine was. My 53 NAA did the same thing a year ago. My problem was a broken second gear( the weak point in the 4 speed trany). I had to pick-up the rear and tow it to the shop, split the tranny tear her down and replace parts.
Wish You Luck, Joe
bizkit
PostPosted: Sun Jun 10, 2007 6:09 am    Post subject: Re: transmission problems need help Reply to specific post Reply with quote
see wherre ur shiftter goes all them notches need to b all lined up together just take a screw driver and work them back n forth and keep them all lined up and u will b in nuetral
