rvirgil_ks
pa don
PostPosted: Sun Mar 22, 2020 5:46 am    Post subject: rvirgil_ks Reply to specific post Reply with quote
would you post a view of gen. to alt. conversion thanks
rvirgil_KS
PostPosted: Sun Mar 22, 2020 7:15 am    Post subject: Re: rvirgil_ks Reply to specific post Reply with quote
Is this what you are wanting?
pa don
PostPosted: Mon Mar 23, 2020 9:10 am    Post subject: Re: rvirgil_ks Reply to specific post Reply with quote
what do you think of the one wire alt. is it a simpler and easyer way to do
old
PostPosted: Mon Mar 23, 2020 9:46 am    Post subject: Re: rvirgil_ks Reply to specific post Reply with quote
1 wire is easier but it has its draw backs.
#1 most take a high RPM to self excite.
#2 some are also known to cause a battery to drain over a long period of time say if it sits a month.
I only have one tractor with a 1 wires all the rest are 3 wire. The 1 wire will charge when it wants and then not charge the next time I use the tractor or start charging after it has run for 15 plus minutes. Plus the 1 wire cost twice what a 3 wire does
rvirgil_KS
PostPosted: Mon Mar 23, 2020 1:34 pm    Post subject: Re: rvirgil_ks Reply to specific post Reply with quote
Yes, the 1 wire are simpler to install.
But I agree with OLD. I prefer a 3 wire for the reasons he has given. I have 2 tractors that came with 1 wire alternator and I converted them both to 3 wire buy changing the regulator.
A person's wiring knowledge and skill are often the determining factor in the choice.
If it works, that is what matters.
Rich'sToys
PostPosted: Mon Mar 23, 2020 9:08 pm    Post subject: Re: rvirgil_ks Reply to specific post Reply with quote
One thing I did is; the wire with the diode on it--instead of running that all the way back to the ignition switch, I just ran it to the + side of the coil. Same connection, just used a lot less wire!
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
