TO-30 wont turn over
nkelly1772
PostPosted: Wed Mar 25, 2020 6:27 am    Post subject: TO-30 wont turn over Reply to specific post Reply with quote
gents,
i have a Harry TO-30 that ran great one day, sat for 2 days before i tried to start it back up to be used, sounded as if the starter got one or two revolutions before everything seemed to seize or lock up. i currently have the motor almost down to bare as far as removing covers and starter. everything visually looks good to me but it doesnt matter how much pressure i apply to the crank it only rotates a 1/4 turn in either direction. is there something i am missing here before i do a complete tear down?? any help would be appreciated. add. the jugs and pistons appear to be fine by visual.
phil(va)
PostPosted: Wed Mar 25, 2020 7:28 am    Post subject: Re: TO-30 wont turn over Reply to specific post Reply with quote
So does the starter run if you hook it up while you have it off the tractor?
nkelly1772
PostPosted: Wed Mar 25, 2020 7:48 am    Post subject: Re: TO-30 wont turn over Reply to specific post Reply with quote
CVPost-phil(va) wrote:
(quoted from post at 08:28:41 03/25/20) So does the starter run if you hook it up while you have it off the tractor?
yes it is operational off the tractor, re-install it and when you bump it, it just hums as if its trying to turn the motor over and it doesnt, checked batteries and tried several different ones to confirm the same result. removed the inspection cover on the fly wheel, no foreign objects to stop the fly wheel. currently have the valve cover off, oil pan, front cover, governor housing, all the spark plugs are out. only thing thats not off at the moment is the water pump but that spins free by hand.
Tom H.
PostPosted: Wed Mar 25, 2020 8:41 am    Post subject: Re: TO-30 wont turn over Reply to specific post Reply with quote
Maybe a valve dropped? Pull the valve cover off and inspect all of the springs for valve stems.
Duner Wi
PostPosted: Wed Mar 25, 2020 9:03 am    Post subject: Re: TO-30 wont turn over Reply to specific post Reply with quote
Take a peek at the starter ring gear and see if it is mounted to flywheel from the transmission side or the engine side. Some of the ring gears mounted from the transmission side tended to move away from engine and lock in to bell housing.
This was mostly a problem with early T020s but parts get moved around sometimes.
Bart CA
PostPosted: Wed Mar 25, 2020 11:12 am    Post subject: Re: TO-30 wont turn over Reply to specific post Reply with quote
Engine may be full of gas if the needle valve leaked
youn may remove spark plugs an try to turn the engine by
hand or with the crank if available then
the gas wil exit from the plug holes. Do not turn ith with
starter the gas will be ignited and set a fire.
It may be otjer causes as suggested by others.
Bart
Ark68SS
PostPosted: Wed Mar 25, 2020 8:00 pm    Post subject: Re: TO-30 wont turn over Reply to specific post Reply with quote
Have you removed the timing gear cover? The governor may have come apart and be jamming the gears.
BillL
marloweg
PostPosted: Thu Mar 26, 2020 9:58 am    Post subject: Re: TO-30 wont turn over Reply to specific post Reply with quote
had one some time ago the clutch came apart spring got stuck in ring gear
Jim L WA
PostPosted: Fri Mar 27, 2020 9:56 am    Post subject: Re: TO-30 wont turn over Reply to specific post Reply with quote
From what a couple of the others said, that actually read your whole post, it sounds like you will need to split the tractor and see what's going on around the flywheel and clutch area. Bummer.
