Ballast Resistor
bholtsclaw
PostPosted: Wed Mar 25, 2020 1:17 pm    Post subject: Ballast Resistor Reply to specific post Reply with quote
Is a balast resistor necessary when doing a 12 volt conversion if the 6 volt coil is replaced with a 12 volt coil. (Ford 8n Tractor)
JMOR
PostPosted: Wed Mar 25, 2020 1:22 pm    Post subject: Re: Ballast Resistor Reply to specific post Reply with quote
bholtsclaw wrote:
(quoted from post at 17:17:36 03/25/20) Is a balast resistor necessary when doing a 12 volt conversion if the 6 volt coil is replaced with a 12 volt coil. (Ford 8n Tractor)
no, as long asit is a 12v coil labeled no resistor required, such as IC-14 from NAPA. There are coils marked 12v, resistor required.
R Geiger
PostPosted: Wed Mar 25, 2020 3:34 pm    Post subject: Re: Ballast Resistor Reply to specific post Reply with quote
JMOR wrote:
(quoted from post at 15:22:38 03/25/20)
Does that hold true for a 8n with a front mount distributor?
JMOR
PostPosted: Wed Mar 25, 2020 3:43 pm    Post subject: Re: Ballast Resistor Reply to specific post Reply with quote
R Geiger wrote:
(quoted from post at 19:34:54 03/25/20)
only if it has been converted to use a round can coil. To the best of my knowledge, there is no front mount square coil that is a true 12v (no resistor required).
HCooke
PostPosted: Wed Mar 25, 2020 3:44 pm    Post subject: Re: Ballast Resistor Reply to specific post Reply with quote
I've been running a 12 volt coil in a 9N for several years with no resistor. YMMV.
JMOR
PostPosted: Wed Mar 25, 2020 7:53 pm    Post subject: Re: Ballast Resistor Reply to specific post Reply with quote
CVPost-HCooke wrote:
(quoted from post at 19:44:18 03/25/20) I've been running a 12 volt coil in a 9N for several years with no resistor. YMMV.
yep, you can get aroud a problem aas long as you never leave key on when stalled. After all, when running the coil current is very low compared to stalled conditions. I would have to look it up, but memory says 25% or less.
Tim PloughNman Daley
PostPosted: Thu Mar 26, 2020 3:12 am    Post subject: Re: Ballast Resistor Reply to specific post Reply with quote
FORD N-SERIES TRACTOR BALLAST RESISTOR; BEFORE S/N 8N-263843:
FORD 8N TRACTOR OEM DASH WIRING; BEFORE S/N 263843:
Tim Daley(MI)
