1850 Diesel Hydra-Power
DG 3
PostPosted: Fri Mar 27, 2020 9:42 am    Post subject: 1850 Diesel Hydra-Power Reply to specific post Reply with quote
I am thinking about buying this tractor. I have been told that when you shift down to low, it stops then takes off. I don't have splitting stands. What would it
cost to get that fixed at a Dealer? Ballpark figure? Thanks in advance!
J. Schwiebert
PostPosted: Fri Mar 27, 2020 10:18 am    Post subject: Re: 1850 Diesel Hydra-Power Reply to specific post Reply with quote
The sprag clutch is wore out. You don't split the tractor to do that. You lift the engine out and remove the hydra power from the engine.
RCP
PostPosted: Fri Mar 27, 2020 11:16 am    Post subject: Re: 1850 Diesel Hydra-Power Reply to specific post Reply with quote
The parts will cost $800 to $1200, labor around $300 if you pull the hydrapower yourself.
Rich
DG 3
PostPosted: Fri Mar 27, 2020 12:43 pm    Post subject: Re: 1850 Diesel Hydra-Power Reply to specific post Reply with quote
Thanks for the replies. I think I read somewhere you can do away with Hydra-Power? Or weld it together?
ziffel
PostPosted: Fri Mar 27, 2020 12:51 pm    Post subject: Re: 1850 Diesel Hydra-Power Reply to specific post Reply with quote
It can be eliminated. Many of them were built without them. You need an "Eliminator Kit" The parts needed to do that can sometimes be found in salvage yards. I have replaced many Hydra-Power units with Straight shafts. I have a complete list of the necessary parts with numbers. Send me an email at arnie@yousq.net if you need a copy. Arnie
tom upton
PostPosted: Fri Mar 27, 2020 1:11 pm    Post subject: Re: 1850 Diesel Hydra-Power Reply to specific post Reply with quote
Hydra powers should be relatively easy to come by. heck u might get lucky and buy a whole parts tractor cheaper than rebuilding one. In my opinion if you are going to use the tractor for much you will regret deleting it. I have a working unit I would sell for $500 if you pick it up. I am in Ontario Canada bout 100 mile north east of T.O.
rrlund
PostPosted: Fri Mar 27, 2020 2:05 pm    Post subject: Re: 1850 Diesel Hydra-Power Reply to specific post Reply with quote
I don't know that it'd stop me from buying it. Mine has been that way for years. I just leave it in direct,no problem.
DG 3
PostPosted: Fri Mar 27, 2020 2:50 pm    Post subject: Re: 1850 Diesel Hydra-Power Reply to specific post Reply with quote
Thanks for that info. Growing up my family all had Farmalls. Mostly 806's and most of them were the same way. We just left the torque forward, no problem. I didn't know if you could drive a hydra-power like that.
RCP
PostPosted: Fri Mar 27, 2020 3:14 pm    Post subject: Re: 1850 Diesel Hydra-Power Reply to specific post Reply with quote
An add on this site for a straight shaft.
Contact: Steve Located in: Norway, IA, USA *
For Sale: Hydra-Power or Over-Under delete from an Oliver 1850 gas tractor. Should fit others. Condition: Good Price: 300
Phone: 3197213066
If the sprague is bad, I would wonder how long the direct drive clutch pack is going to hold and sometimes like a Farmall they are hard to shift when in direct.
Rich
