Cable End
Steve@Advance
PostPosted: Wed Mar 25, 2020 7:41 pm    Post subject: Cable End Reply to specific post Reply with quote
I've got an old British built OD grinder in the shop.
It has a counter weight that hangs on a 1/8" cable that keeps the slack pulled out of the wheel head lead screw. My guess is the weight probably weighs 150#.
The cable pulled out of the ball that was soldered on the end. I'm replacing the cable and can make a new ball. Probably a sleeve will be easier, doesn't matter, just needs something on the end to hold it.
Any suggestions for attaching the sleeve? Will plumbing solder and flux paste work? Or crimp it in the press? Or both? Brass or steel?
Or should I try to find a factory crimped cable? Any sources that are interested in a one time sale?
I don't want to take any chances of it failing, a real bear to get to!
Thanks!
John Garner
PostPosted: Wed Mar 25, 2020 8:06 pm    Post subject: Re: Cable End Reply to specific post Reply with quote
My suggestion is to contact a wire rope and rigging agency near you, and have them make a replacement cable for you. I've found the wire rope specialists can almost always make what I need faster and usually cheaper that I could do the job myself.
Janicholson
PostPosted: Wed Mar 25, 2020 8:30 pm    Post subject: Re: Cable End Reply to specific post Reply with quote
Double up on a pair of 1/8" cable clamps Scroll down to find them they will do it if there is any room at all. Jim
clamps.
JD Seller
PostPosted: Wed Mar 25, 2020 9:41 pm    Post subject: Re: Cable End Reply to specific post Reply with quote
Just use an aluminum cable sleeve. You can get them that have a single hole or double hole. You just crimp them on the cable. If you have the room I use the double eye one and loop the cable back around the sleeve. I them crimp it ,this way if the sleeve slips it will just tighten the loop and still not come off.
These can easily be crimped with just regular vice grips. Just crimp it with the jaws parallel with the cable. I have used them this way on overhead door cables that weight a lot more than your weight.
MarkB_MI
PostPosted: Thu Mar 26, 2020 3:18 am    Post subject: Re: Cable End Reply to specific post Reply with quote
The ball is probably swaged on rather than soldered. These types of fittings are commonly used on sailboats and aircraft. Since special equipment is needed to swage the ball, your best bet is to order a custom cable. One source is Aircraft Spruce. Or, if you are close to a marina that works on sailboats, they may be able to make you a cable.
showcrop
PostPosted: Thu Mar 26, 2020 4:37 am    Post subject: Re: Cable End Reply to specific post Reply with quote
2X aluminum cable sleeve. My local hardware carries them. We used them when putting up hi-tensile electric fence.
cwtech
PostPosted: Thu Mar 26, 2020 4:38 am    Post subject: Re: Cable End Reply to specific post Reply with quote
I have seen steel cables with a bead of weld on the end.
Maybe insert the cable through a sleeve or ball, bead of weld on the end of the cable, then crimp the sleeve or ball?
DoubleO7
PostPosted: Thu Mar 26, 2020 5:02 am    Post subject: Re: Cable End Reply to specific post Reply with quote
Go to mcmaster carr
https://www.mcmaster.com/wire-rope-ends
You might want #3869T63
Maybe
But see if your local rigging supply has it and can swage it to your cable.
M Carr also sells wire rope assembies with ball end, made to order.
Russ from MN
PostPosted: Thu Mar 26, 2020 5:25 am    Post subject: Re: Cable End Reply to specific post Reply with quote
I like to put Flemish eyes on cable, they work well and look professional, I use a piece of pipe for a sleeve. Google will show you how to do it if you're interested.
Blackhole49
PostPosted: Thu Mar 26, 2020 5:28 am    Post subject: Re: Cable End Reply to specific post Reply with quote
If you use these, remember, never saddle a dead horse.
Janicholson
PostPosted: Thu Mar 26, 2020 1:42 pm    Post subject: Re: Cable End Reply to specific post Reply with quote
Good rule. Put the loose end back through both clamps with the loose end being in contact with the bolt U, not the iron "saddle" Jim
The rule
Southern Ray
PostPosted: Thu Mar 26, 2020 4:24 pm    Post subject: Re: Cable End Reply to specific post Reply with quote
Cable stops are available at your local hardware store. I use a square nut cut in half for a die and mash the stop in a hydraulic press.
I like the Flemish loop in my cables. With a little patience you can make a nice loop. I use a piece of copper for the crimp.
