Mounting fenders to Deere canopy issue
fdt860
PostPosted: Wed Mar 25, 2020 8:04 pm    Post subject: Mounting fenders to Deere canopy issue Reply to specific post Reply with quote
I am making a 4020 canopy and have noticed that Deere 4020 canopy has holes to mount fenders. But they are not centered above the axle mounting holes (like they would have been on fenders stand), but rather offset 3 inches to the rear.
I cannot see this going very well, because the fender would be too far back and tractor will look ugly.
So I am seriously thinking about skeeping those hole.
What do you think?
Bob Bancroft
PostPosted: Thu Mar 26, 2020 1:43 am    Post subject: Re: Mounting fenders to Deere canopy issue Reply to specific post Reply with quote
I am surprised, in that I never noticed that. I put an OEM "roll-gard" on my 2520. I was annoyed that when I mounted the fenders to the roll-gard, I had no choice for height, as I had before. I didn't notice the fore/aft discrepancy.
I would think with your self-construction, you would be able to compromise/improvise- move holes, even if you only end up using three bolts on fender- or even incorporating the original fender stands in your design?
fdt860
PostPosted: Thu Mar 26, 2020 4:55 am    Post subject: Re: Mounting fenders to Deere canopy issue Reply to specific post Reply with quote
CVPost-Bob Bancroft wrote:
(quoted from post at 02:43:26 03/26/20) I am surprised, in that I never noticed that. I put an OEM "roll-gard" on my 2520. I was annoyed that when I mounted the fenders to the roll-gard, I had no choice for height, as I had before. I didn't notice the fore/aft discrepancy.
[img]https://media.sandhills.com/img.axd?id=4155504763&wid=4326159703&rwl=False&p=&ext=&w=639&h=480&t=&lp=TH&c=True&wt=False&sz=Max&rt=0&checksum=cGyX446ED%2bEyA8XmmA%2bo4PVLUBkOy4p0eukAz6JAVC8%3d[/img]
fdt860
PostPosted: Thu Mar 26, 2020 4:59 am    Post subject: Re: Mounting fenders to Deere canopy issue Reply to specific post Reply with quote
Trying again:
Now you can see better the fore / oft offset. Putting only 3 holes will allow to move the fender forward, but keeping the fender stand is even simpler. I am making the ROPS and canopy exactly like the John Deere one (except metric bolts because I am back to France...)
Dan in North Houston
PostPosted: Thu Mar 26, 2020 5:31 am    Post subject: Re: Mounting fenders to Deere canopy issue Reply to specific post Reply with quote
My 4020 roll guard does not have any holes like that.
Bob Bancroft
PostPosted: Thu Mar 26, 2020 8:21 am    Post subject: Re: Mounting fenders to Deere canopy issue Reply to specific post Reply with quote
I suppose it depends on where the tractor wheels are set. On my 2520, with the wheels set in as tight as possible, for 30" row crop work, there's no room in there for the original fender mounts.
Fordy20
PostPosted: Thu Mar 26, 2020 11:50 am    Post subject: Re: Mounting fenders to Deere canopy issue Reply to specific post Reply with quote
Fenders aren?t mounted to roll gard on mine.
D-
PostPosted: Thu Mar 26, 2020 2:39 pm    Post subject: Re: Mounting fenders to Deere canopy issue Reply to specific post Reply with quote
Probably moving the fenders back allows easier movement
on and off tractor.
larryanderson
PostPosted: Fri Mar 27, 2020 4:52 am    Post subject: Re: Mounting fenders to Deere canopy issue Reply to specific post Reply with quote
Dan,I have had several and also taken off many Stolper and Hinsen cabs and all the factory Roll-Gard I have seen had the existing holes.Some of the after market ones are hard to tell difference except holes.
newgenjdcollector
PostPosted: Fri Mar 27, 2020 8:06 am    Post subject: Re: Mounting fenders to Deere canopy issue Reply to specific post Reply with quote
I have done it both ways. Mounting to the axle is a little easier for me but there are a couple little quirky issues if you have if you want the fenders in tight. One you have turn the foot on the bracket outward toward the tire. next you have the bolt heads of the fenders that will rub on the side of the roll bar, which keeps the fender pushed out. So I ended up grinding the heads almost flat and that helps a lot. Mounting to the bar does put the fender back about 3". I did that on the last tractor I restored and it seemed fine. It had 38" rubber. One benefit of doing so is that it gives you a tiny bit more room for getting on and off. I suppose a guy could make an adapter bracket that would mount to bar and push the fender forward where it normally would be. I have actually had that though before.
fdt860
PostPosted: Fri Mar 27, 2020 12:05 pm    Post subject: Re: Mounting fenders to Deere canopy issue Reply to specific post Reply with quote
Thank you for advices. The fenders on my 4020 are mounted on 2 inch tall spacers to allow for more clearance under 18.4_38 tires. Maybe I should make the canopy so it accommodate for that and the rear offset.
fdt860
PostPosted: Tue May 12, 2020 10:48 am    Post subject: Re: Mounting fenders to Deere canopy issue Reply to specific post Reply with quote
I have found better pictures to illustrate the problem. I have decided to make the canopy without fender mounts. Those would have weaken the canopy structures anyway in case of Rollover.
Other case, this is quite the Frankenstein tractor!
