3688 fuel gauge doesn't work
BonaparteSouth
PostPosted: Fri Apr 03, 2020 2:50 pm    Post subject: 3688 fuel gauge doesn't work Reply to specific post Reply with quote
Has two fuel tanks, what is best way to trouble shoot this problem? Top sensor looks good.
Bob
PostPosted: Fri Apr 03, 2020 3:49 pm    Post subject: Re: 3688 fuel gauge doesn't work Reply to specific post Reply with quote
One sender will have two wires connected it's insulated terminals, and the other will have only one. (ground wires don't count for this.)
With the key switch "ON", measure the DC voltage at each of those three terminals with a digital meter and post back with the numbers.
BonaparteSouth
PostPosted: Sun Apr 05, 2020 4:24 am    Post subject: Re: 3688 fuel gauge doesn't work Reply to specific post Reply with quote
Put the 3688 on shop pad to drain oil lastnight, started working at get to lower fuel gauge and found the sender wire is only about 6" long ! now I will have to run a jumper wire to top sender I assume? I&T manual doesn't have wiring diagram. neither does factory manual.
BonaparteSouth
PostPosted: Sun Apr 05, 2020 4:48 am    Post subject: Re: 3688 fuel gauge doesn't work Reply to specific post Reply with quote
Found wiring diagram in older shop manual from I&T manual for my 5488. Wire to center post of lower sender goes directly to gauge on dash. I think i've got this figured out, just more time needed. tanxs Ken
Bob
PostPosted: Sun Apr 05, 2020 5:23 pm    Post subject: Re: 3688 fuel gauge doesn't work Reply to specific post Reply with quote
GOOD JOB!
Post back if any more help is needed!
