830 CK Hydraulics
Wicksfield
PostPosted: Fri Apr 10, 2020 1:51 pm    Post subject: 830 CK Hydraulics Reply to specific post Reply with quote
My 1968 830 has dual hydraulics. New Hy-Tran and hydraulic filter a couple years ago. I've noticed recently that the lever to
activate the remote cylinder pushes or pulls hard. Once it snaps into place, it will hold until the cylinder is fully extended or
retracted then pops back into neutral as it should. Both remote levers have the same symptoms. Lever pushes (or pulls) hard into
position. I will say, if I operate the lever back and forth while in the shop, tractor running, with hoses not hooked, only the
first time will the lever push hard. Next time easy as it should. Then, a bit later, pushes hard again. You guys have any idea
what the problem may be?
Thanks for your response.
Kasey00
PostPosted: Mon Apr 13, 2020 12:59 am    Post subject: Re: 830 CK Hydraulics Reply to specific post Reply with quote
I did notice the bit about the selector valve after more reading. I have what looks to be a two spool remote hydraulic block with only one spool running at the moment.
Kasey00
PostPosted: Mon Apr 13, 2020 11:41 pm    Post subject: Re: 830 CK Hydraulics Reply to specific post Reply with quote
I did notice the bit about the ipage selector valve after more reading. I have what looks to be a two spool remote hydraulic block with only one spool running at the moment.
