Planting has started in the kingdom
jon f mn
PostPosted: Sun Apr 19, 2020 7:30 pm    Post subject: Planting has started in the kingdom Reply to specific post Reply with quote
Got started on field work this weekend. My grandson Gage came up to run the 830. Started him off with discing some corn stalks with the SA 14' disc.
Had the crew lined up this morning so took a couple pics.
Even got stuck once, there were some huge ruts from a big combine and I was trying to get them closed and fell in. Got them closed some and it's supposed to be dry for a while so I hope to get them worked down finally.
I went and got Jeff's cultivator because I hoped it would help drag those ruts shut better than the disc. Seemed to work better.
Was fun having two old cases working in the same field at the same time.
Last was to put the 830 on the drill to plant some oats and grass for hay.
The ground is really looking good this year. The fall plowing worked up perfect. The spring plowing as usual had some spots that will have some lumps, but much better than last year. Last year I couldn't get anywhere near where the ruts are that I got stuck in. But I worked on the ditch some and been picking away at them and I think they should be fixed up pretty good after this year.
Finished the day today by fixing a neighbor's fertilizer auger that had rusted out. The flighting is stainless, but the tube is steel. So the tube rotted away. I replaced about 2'
The weather looks good for the next week so hopefully the rest of the fields dry up so I can plant corn. Hope next weekend for that.
View user's profile AIM Address
Don Rudolph
PostPosted: Sun Apr 19, 2020 8:34 pm    Post subject: Re: Planting has started in the kingdom Reply to specific post Reply with quote
Great to see that Case equipment working the fields. Thanks for posting these pics Jon. Don
1370rod
PostPosted: Mon Apr 20, 2020 4:57 am    Post subject: Re: Planting has started in the kingdom Reply to specific post Reply with quote
Good to see the progress Jon, what small grain was going in? Last weeks snow is for the most part gone and things will begin to happen soon around here, Rod.
jon f mn
PostPosted: Mon Apr 20, 2020 6:41 am    Post subject: Re: Planting has started in the kingdom Reply to specific post Reply with quote
Planted oats as a cover for some grass hay. Planted some alfalfa last year and wanted a little grass hay for the horse people if they want it.
Case Nutty 1660
PostPosted: Mon Apr 20, 2020 6:58 am    Post subject: Re: Planting has started in the kingdom Reply to specific post Reply with quote
jon,, All Looks Great I was going to say this on the phone this morning but we got side tracked lol your plow will fill those ruts in fast and easy by leaving the tail wheel up and just using the front bottom or two, in case you had not thought of it yet,, we used to do that every spring before we installed water shed dikes in a farm we had at the time as run off would cut trenches up to 6 feet deep at times in the sandy hill ground,, you may have a reason for not using it I have not thought of though
