Ford/Newholand TM125 brakes
cliffswan
PostPosted: Sun Apr 26, 2020 8:06 am    Post subject: Ford/Newholand TM125 brakes Reply to specific post Reply with quote
Brakes on my TM125 quit working. Tractor has only got rear brakes. Checked brake fluid reservoir and it was empty. Filled with IRONGUARD brake oil as recommended by dealer. Bled brake Left side pressured up as expected. Could not get pressure on right side. Fluid dissapeared from reservoir while tractor sat overnight. Suspected seals on brake piston gone so pulled wheel and axle housing. Seal on piston degraded. Replaced seals and put tractor back together.
Bled brakes. Pressure normal on Left side but nothing on right. Switched master cylinders and still cannot get any resistance on right brake pedal. Left good. Tore tractor apart and could see right brake piston moving when pumping foot pedal.
Put tractor together and still cannot get right brakes to work..Reservoir has held fluid for several days so not leaking past piston seals.
Any secrets on bleeding brakes on TM tractors? Am at an impasse
as to what to try next.
Appreciate any advice. Thanks Cliff
