1960 case 12 ft 3 point field cultivater
JOE-ILLINOIS
PostPosted: Wed May 06, 2020 3:14 am    Post subject: 1960 case 12 ft 3 point field cultivater Reply to specific post Reply with quote
Hi Neighbors are restoring a cultivater and can not figure out the model number so they can get a manual it has 2 or 3 rows of shanks, it is the one that they used to pull a planter behind with the dolly wheel in the middle, thanks
Straw Boss
PostPosted: Wed May 06, 2020 9:14 am    Post subject: Re: 1960 case 12 ft 3 point field cultivater Reply to specific post Reply with quote
The earlier T-13 was only a single tool bar so it is probably the K410 which could have a double tool bar.
Tool bars on the K410 could be solid or tubular and shanks were also available in rigid style instead of the double coil shank.
Says right in the literature it can be mounted in front of a 4-row planter.
If your cultivator has three rows of shanks, then it's probably a FC series cultivator. I'll add a picture of it as well.
casecollectorsc
PostPosted: Wed May 06, 2020 10:26 am    Post subject: Re: 1960 case 12 ft 3 point field cultivater Reply to specific post Reply with quote
Bought the K-410 unit brand new in parts bags in about 72. Used it ahead of a Case 434 planter for many years with the Optimum Tillage Hitch in between. Later lengthened the 410 to 20' to use ahead of a 20' press drill...still have both.
Straw Boss
PostPosted: Wed May 06, 2020 11:43 am    Post subject: Re: 1960 case 12 ft 3 point field cultivater Reply to specific post Reply with quote
Cover of the Assembly and Ops manual and pictures of the hitch.
Straw Boss
PostPosted: Wed May 06, 2020 11:46 am    Post subject: Re: 1960 case 12 ft 3 point field cultivater Reply to specific post Reply with quote
Pictured mounted on different styles of cultivators.
Straw Boss
PostPosted: Wed May 06, 2020 11:50 am    Post subject: Re: 1960 case 12 ft 3 point field cultivater Reply to specific post Reply with quote
Total package put together.
They called this the Optimum Tillage Cult-Planter. Not to be confused with the Optimum Tillage Chisel-Planter which was assembled as one implement.
Straw Boss
PostPosted: Wed May 06, 2020 11:55 am    Post subject: Re: 1960 case 12 ft 3 point field cultivater Reply to specific post Reply with quote
I've been fortunate enough to have seen your hitch. Thank you for the tour that day. It's the only one I've ever seen.
casecollectorsc
PostPosted: Wed May 06, 2020 7:40 pm    Post subject: Re: 1960 case 12 ft 3 point field cultivater Reply to specific post Reply with quote
That FCM mounted field cultivator was the a Glencoe in Case colors. Have a 16.5 Glencoe pull type I changed to a mounted field cultivator. Bought it new in 68.
