1520 Hydraulics Stuttering
2510Paul
PostPosted: Sun May 10, 2020 11:52 am    Post subject: 1520 Hydraulics Stuttering Reply to specific post Reply with quote
Friend has 1520 with loader. Loader hydraulics stutter up and, as I recall, down also. Bucket works this way as well. What might be causing this? Thanks. Paul.
Tx Jim
PostPosted: Sun May 10, 2020 12:23 pm    Post subject: Re: 1520 Hydraulics Stuttering Reply to specific post Reply with quote
Easiest & cheapest things to do is change hyd filter then check/clean trans oil sump screen. Also attach hyd gauge to system to check stand-by pressure which should be 2250 psi. What type valve controls loader & how is it attached to tractor hyd system. With 3 pt raised engine running look in hyd filler hole behind seat for moving oil.
2510Paul
PostPosted: Mon May 11, 2020 2:34 pm    Post subject: Re: 1520 Hydraulics Stuttering Reply to specific post Reply with quote
Hi TX Jim. Thanks for your response. I assume the 2250 psi should show up when measured at the rear SCV. Correct?
Thanks again.
Paul
Tx Jim
PostPosted: Tue May 12, 2020 3:26 am    Post subject: Re: 1520 Hydraulics Stuttering Reply to specific post Reply with quote
Yes check pressure at scv. What type valve controls FEL? I suggest to disconnect & cap the power steering supply line then test hyd operation. Power steering valves have a history of failed o-rings or valve bodies causing hyd problems
