Deere 755 slow starting after sitting overnight
Goto page 1, 2  Next
Cnv65stang
PostPosted: Mon May 11, 2020 5:24 pm    Post subject: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
I just got this tractor. It is a Deere 755 either a 60" belly mower. I am starting to have a bad feeling about the deal. The tractor shows 515 hours. Previous owner claims it was working prior to me picking it up... but isnt working now. tractor is clean and does not show any signs of high hours. My problem is that in the morning the tractor cranks 15-20 seconds or so and stumbles then fires up and runs great. If I shut it down and then restart later that day it fires right up and till runs great... just starts slow after sitting overnight. Any help would be appreciated!
J Hamilton
PostPosted: Mon May 11, 2020 5:51 pm    Post subject: Re: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
I have a John Deere F935 with a diesel and
I just set the throttle just under half and
it does fine until the engine warms up
otherwise it will try to stumble too. Might
check the glow plugs, I think I need to
change them on mine.
Scott 730
Check glow plugs for proper operation.
Gene Davis (Ga.)
PostPosted: Mon May 11, 2020 6:13 pm    Post subject: Re: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
I have a 650 and it is a smaller 2 cylinder version of this engine, the 750 series is a 3 cylinder. These tractors
are really Yanmars just made for Deere. They do not use glow plugs for cold starting. They use a thing known as a
thermostart system like some of the older Massey Ferguson/Perkins engines did. You are supposed to turn the key to
the left for 30-45 seconds and it heats an element in the intake that actually starts a small fire in the intake to
heat the air. When the engine cranks it sucks the flame out and all is well. My 650 is an 1981 model and it has
always started well if I use the correct cold start procedure for starting it.
Cnv65stang
PostPosted: Tue May 12, 2020 2:40 am    Post subject: Re: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
The 755s and 655s do have glow plugs, the 855s and 955s do not. I dont know about the 50 series tractors for sure. I know to turn the key wait for the plug light to go off, then try to start. Probably should have mentioned that originally.
Cnv65stang
PostPosted: Tue May 12, 2020 2:43 am    Post subject: Re: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
I am kinda new to diesels. I have a couple of gas tractors. How do I check the glow plugs for correct operation?
buickanddeere
PostPosted: Tue May 12, 2020 3:01 am    Post subject: Re: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
How cold is the ambient temperature ?
If the operator's manual was lost and the instructions with it on how to use glowplugs etc. A call to the nice folks at 1-800-522-7448 will obtain the info on CD or hard copy.
Tx Jim
PostPosted: Tue May 12, 2020 3:51 am    Post subject: Re: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
Welcome to YT
I agree if you don't have an operators manual for your tractor you need to acquire an OM & read it. Some glow plugs are activated automatically during start cycle & some GP's must be activated by operator. One can utilize a VOM or ammeter to check GP's. Glow plug for your tractor if needed is part # M87919
Cnv65stang
PostPosted: Tue May 12, 2020 4:07 am    Post subject: Re: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
Thanks for the welcome. I have read on here for years just never posted.
I have the operators manual and I have read it. I know when and how to use the glow plugs, and have been while starting it. Temp outside has ranged from 45 to 60 with same results when trying to start it.
Cnv65stang
PostPosted: Tue May 12, 2020 4:10 am    Post subject: Re: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
I have looked up glow plug testing and will do that when I get outside to look at it today
J Hamilton
PostPosted: Tue May 12, 2020 8:47 am    Post subject: Re: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
855 tractors do have glow plugs. We have
two of those tractors where I work.
Cnv65stang
PostPosted: Tue May 12, 2020 9:34 am    Post subject: Re: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
Ok. Put ohm meter (cheap one from harbor freight) on it. When I touched the two leads together I got a reading of 0.6. Whwn I touched the negative terminal to the negative batt post and the positive to the top of the glow plug I got a 1 at the left side of the screen which means no reading. I assume this means they are bad. I tested the timer and I got a little more than 12 volts for about 10 seconds then I got a 0.
I have a 755. I know it has the glow plugs but everything I have read says the 855s dont, but I am not really concerned about the 855s because that isnt what I have. I was just responding to another poster.
buickanddeere
PostPosted: Tue May 12, 2020 9:53 am    Post subject: Re: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
Cnv65stang wrote:
(quoted from post at 13:34:53 05/12/20) Ok. Put ohm meter (cheap one from harbor freight) on it. When I touched the two leads together I got a reading of 0.6. Whwn I touched the negative terminal to the negative batt post and the positive to the top of the glow plug I got a 1 at the left side of the screen which means no reading. I assume this means they are bad. I tested the timer and I got a little more than 12 volts for about 10 seconds then I got a 0.
On the ohms or volts setting ?
Cnv65stang
PostPosted: Tue May 12, 2020 11:17 am    Post subject: Re: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
I tested the glow plugs on ohms
I tested the red timer wire in volts
Pulled the glow plugs and got a nothing reading.
Cnv65stang
PostPosted: Tue May 12, 2020 11:20 am    Post subject: Re: Deere 755 slow starting after sitting overnight Reply to specific post Reply with quote
Are these glow plugs the NGK y702r (1065)?
Thanks.
David
Goto page 1, 2  Next
Page 1 of 2
