1970 2110LCG 3 cyl gas governor issues?
Steve Brussell
PostPosted: Tue May 26, 2020 2:53 pm    Post subject: 1970 2110LCG 3 cyl gas governor issues? Reply to specific post Reply with quote
Hi folks. My 2110 started to have this problem last year and it has continued this year. I use the tractor for mowing. I have a 6’ Ford flail behind it. Rpms will not stay and it constantly accelerates to over 2100. Throttle stays put but I move it to lower the rpm. It will not stay at pto speed and the throttle is not moving. I lubricated the linkage and it appears to be free. It does have a foot throttle but I seldom use it. Is this indicative of a governor issue. I have never been into one before. It has the Holley carb and it starts and idles ok.
Mike(NEOhio)
PostPosted: Tue May 26, 2020 4:54 pm    Post subject: Re: 1970 2110LCG 3 cyl gas governor issues? Reply to specific post Reply with quote
First make sure all the governor linkages are not damaged and the correct length. Operating manual covers the procedure. Not fun, though.
Ultradog MN
PostPosted: Wed May 27, 2020 2:25 am    Post subject: Re: 1970 2110LCG 3 cyl gas governor issues? Reply to specific post Reply with quote
Those governors are simple and rarely go haywire. But...
You pretty much Have to pull the tin and radiator off the tractor to get at it.
If you pull the governor cover off you should be able to grab the front pins on the bell and slide the bell in/out on its shaft VERY easily.
There is a small oil tube that comes out of the block under the governor/distributor drive that supplys it with engine oil.
The one I had go bad had a lot of waxy buildup in the engine and that oil line was plugged
so the bell shaft did not slide in/out properly.
In your case I would at least loosen the connections on both ends of that little oil line and wiggle it to see if it leaks with the engine running. Don't remove the line as you need to pull the gov/dist housing off to remove/reinstall it and that's a much bigger job
I would at least check for oil at the tube before trying to adjust the linkage.
Ford went from a 2 arm gov to a 1 arm gov sometime around when your tractor was built. The 1 arm is easier to adjust.
First photo shows the bell in place.
Photo 2 shows the bell in my hand and shaft that slides in/out.
Steve Brussell
PostPosted: Wed May 27, 2020 2:49 am    Post subject: Re: 1970 2110LCG 3 cyl gas governor issues? Reply to specific post Reply with quote
Thanks for the advice and pictures. I will check it out.
