50 series steering
Johnboynotbilly
PostPosted: Sun May 31, 2020 5:47 pm    Post subject: 50 series steering Reply to specific post Reply with quote
A few months back my Uncle Bill and I were pulling off my 50 to get it started. I ran into the back of the G after the 50 cranked up and it smashed the wheels all the way to right real hard. I was glad I didn't have my thumbs inside the steering wheel. Every since then, it has been real.hard to turn it back to the left. Turns to the right okay though. Anyone have any thoughts on what could be wrong, what to check?
Paul_IN
PostPosted: Sun May 31, 2020 6:02 pm    Post subject: Re: 50 series steering Reply to specific post Reply with quote
It may have damaged one of the bearings on each end of the
steering shaft gear when the wheels jammed to full lock. The other
bearing is still okay and able to take the thrust load when you steer
left.
Johnboynotbilly
PostPosted: Sun May 31, 2020 6:13 pm    Post subject: Re: 50 series steering Reply to specific post Reply with quote
That makes a lot of sense. I'll check that tomorrow afternoon. Thanks.
deeretails
PostPosted: Mon Jun 01, 2020 3:40 am    Post subject: Re: 50 series steering Reply to specific post Reply with quote
Manual or power steering?
Johnboynotbilly
PostPosted: Mon Jun 01, 2020 4:39 am    Post subject: Re: 50 series steering Reply to specific post Reply with quote
Manual.
ET
PostPosted: Mon Jun 01, 2020 5:12 am    Post subject: Re: 50 series steering Reply to specific post Reply with quote
I think when you smashed in the nose it
moved the steering valve adjustment back
slightly. You need to recenter the
steering valve.
Johnboynotbilly
PostPosted: Mon Jun 01, 2020 5:29 am    Post subject: Re: 50 series steering Reply to specific post Reply with quote
CVPost-ET wrote:
(quoted from post at 06:12:27 06/01/20) I think when you smashed in the nose it
steering valve.
Which valve are you referring to?
ET
PostPosted: Mon Jun 01, 2020 9:51 am    Post subject: Re: 50 series steering Reply to specific post Reply with quote
It's on the right side of the worm gear
housing. It has 2 steel lines going down
to the rotary cylinder and a rubber
pressure line feeding it.
fixerupper
PostPosted: Mon Jun 01, 2020 6:28 pm    Post subject: Re: 50 series steering Reply to specific post Reply with quote
His 50 has manual steering. No power steering lines there.
Johnboynotbilly
PostPosted: Tue Jun 02, 2020 8:17 am    Post subject: Re: 50 series steering Reply to specific post Reply with quote
Correct, it has manual steering. I replaced the rear worm gear bearing yesterday and it did not improve at all. Does anyone know if someone offers a steering pedestal rebuild kit?
