wd 45 won''t move
Goto page 1, 2  Next
Mike in Ohio
PostPosted: Tue Jun 02, 2020 2:08 pm    Post subject: wd 45 won''t move Reply to specific post Reply with quote
Dad was bushogging today, and the tractor just quit moving. He said he heard sort of a grinding noise just before it happened. Pto works fine, hydraulics work fine. We tried to tow it in and the rear wheels won't turn at all. It was in neutral.
When running it just boggs and stalls if you try to move it. hand clutch position makes no difference. With the hand clutch disengaged the foot clutch should be able to be released, but it still boggs and dies.
Everything was working fine last time he used it.
I need some suggestions on where to start trouble shooting.
Thanks.
Mike in Ohio
PostPosted: Tue Jun 02, 2020 4:04 pm    Post subject: Re: wd 45 won''t move Reply to specific post Reply with quote
Talked to Dad again he says it more of a pinging sound than a grinding sound. Also the trans shifts into all gears normally. Wheels just won't move.
Tramway Guy
PostPosted: Tue Jun 02, 2020 5:20 pm    Post subject: Re: wd 45 won''t move Reply to specific post Reply with quote
Your description of the symptoms are not consistent. You say
the PTO and hydraulics work fine; but the engine stalls when
you let out the foot clutch, regardless of the hand clutch
status.
Really?
funky_g00
PostPosted: Tue Jun 02, 2020 5:39 pm    Post subject: Re: wd 45 won''t move Reply to specific post Reply with quote
If it runs with the transmission in neutral and both clutches engaged, then you probably siezed/shelled a bearing in the differential.
Mike in Ohio
PostPosted: Tue Jun 02, 2020 6:17 pm    Post subject: Re: wd 45 won''t move Reply to specific post Reply with quote
The engine didn't actually stall it bogged badly and I put the clutch back in before it did. It did this with the hand clutch in both positions. When we tried to tow it in neutral, neither rear wheel would turn. I know the hand clutch thing doesn't make sense, but that is what it did. The gears will grind if you try to force them just like normal, they are spinning.
Mike in Ohio
PostPosted: Tue Jun 02, 2020 6:19 pm    Post subject: Re: wd 45 won''t move Reply to specific post Reply with quote
I should have said it does this in gear, in neutral pto and hydraulics work fine.
Little Ed
PostPosted: Tue Jun 02, 2020 6:44 pm    Post subject: Re: wd 45 won''t move Reply to specific post Reply with quote
Just a thought. I once had a pickup that had the little shaft that connects the spider gears slip out and bind up on a projection in the housing. Heard a moderatlely loud snap, but it was still moving, so I continued on my way home. When I next went to move it, I got about fifty feet and then it locked up. That would lock the diff and the output from the trans.
WC47
PostPosted: Tue Jun 02, 2020 7:41 pm    Post subject: Re: wd 45 won''''t move Reply to specific post Reply with quote
CVPost-Little Ed wrote:
(quoted from post at 19:44:12 06/02/20) Just a thought. I once had a pickup that had the little shaft that connects the spider gears slip out and bind up on a projection in the housing. Heard a moderatlely loud snap, but it was still moving, so I continued on my way home. When I next went to move it, I got about fifty feet and then it locked up. That would lock the diff and the output from the trans.
Have you checked rear end oil? Pinion bearing locked up or spider gear pin came part way out. MACK
Mike in Ohio
PostPosted: Tue Jun 02, 2020 7:58 pm    Post subject: Re: wd 45 won''''t move Reply to specific post Reply with quote
Dad is notorious for not checking fluids, I will check, but I think maybe it is too late to just top it off. Think I will start by pulling the diff cover and see what I can see. Problem is it is still in the field.
rustred
PostPosted: Tue Jun 02, 2020 8:21 pm    Post subject: Re: wd 45 won''t move Reply to specific post Reply with quote
are you sure its not stuck in two gears at once? that will bog her down and stall it. pull the gear shift and check.
Mike in Ohio
PostPosted: Tue Jun 02, 2020 8:41 pm    Post subject: Re: wd 45 won''t move Reply to specific post Reply with quote
Possible, but he was just cruising along in first gear, wasn't trying to shift, I will check though. Thanks
Aaron SEIA
PostPosted: Wed Jun 03, 2020 2:35 am    Post subject: Re: wd 45 won''''t move Reply to specific post Reply with quote
I'd bet you'll find the rear end empty and the pinion bearings locked up. Take the lift arms off and remove the differential cover.
AaronSEIA
Aaron SEIA
PostPosted: Wed Jun 03, 2020 2:58 am    Post subject: Re: wd 45 won''''t move Reply to specific post Reply with quote
AaronSEIA
WC47
PostPosted: Wed Jun 03, 2020 4:43 am    Post subject: Re: wd 45 won''t move Reply to specific post Reply with quote
Have you checked the oil in rear end? Pinion bearing locked up or spider gear pin came part way out. MACK
Mike in Ohio
PostPosted: Wed Jun 03, 2020 3:59 pm    Post subject: Re: wd 45 won''''''''t move Reply to specific post Reply with quote
Yep, almost no oil, but much less metal in the bottom than I expected. We got it to move long enough to get it in the shop. The noise seems to be mostly on the right, so I am going to start by pulling the final drives off and checking the bearings on the axle. Still need to pull the trans top off to look in there. Can't do much else till I get my cherry picker back from a friend. It has set in the back of the shop for 3 years until he needed it, of course now I need it too, never fails.
Do you guys know who has bearings for this. I have a parts manual with the part numbers, but know nobody who can cross them over. Also want to do the brakes while I have it apart, so any source for brake parts is also appreciated.
Thanks again for all the help.
Goto page 1, 2  Next
Page 1 of 2
