9n PTO cap/guard
SDE
PostPosted: Sun Jun 07, 2020 11:13 am    Post subject: 9n PTO cap/guard Reply to specific post Reply with quote
When this cap is tight, there is a gap of about .08 between the flange on the cap and the tractors PTO housing. The depth of the cap, (threaded part) from the end, to the flange is .82 and the depth of the threaded housing is .74. It always looks like it is loose when it is indeed tight. Is this the wrong cap for this tractor? Is there supposed to be a gasket on it that would be a .10 thick to fill the gap? Or is the end of the cap supposed to bottom out in the housing.
TY
SDE
shaun wallace
PostPosted: Sun Jun 07, 2020 11:54 am    Post subject: Re: 9n PTO cap/guard Reply to specific post Reply with quote
Think there was 4 different styles of pto covers used thru N production. Some one has posted pic of all that were used.
SDE
PostPosted: Sun Jun 07, 2020 5:14 pm    Post subject: Re: 9n PTO cap/guard Reply to specific post Reply with quote
I found a schematic that showed the cap having straight sides. Mine has a flange and so it must be for another tractor.
TY
SDE
Tim PloughNman Daley
PostPosted: Mon Jun 08, 2020 12:37 pm    Post subject: Re: 9n PTO cap/guard Reply to specific post Reply with quote
Only two OEM PTO caps were used, all others are aftermarkets. The first 9N cap was cast iron and shorter. The 2N introduced the steel version, longer, and used thru the NAA. When the 1-3/8 PTO splined shaft was introduced, it was a tad longer than the original hence they offered a different cap -this is the one with the squared off end. Was your shaft changed and you are using the OEM cap?
PTO CAPS
NOTE: The 9N-726 cap is cast iron; the 2N-726 cap is stamped steel. Both have identical Thread Size of 2-5/8"-12 UN 2A.
Tim Daley(MI)
SDE
PostPosted: Tue Jun 09, 2020 4:31 am    Post subject: Re: 9n PTO cap/guard Reply to specific post Reply with quote
The one on my 9n is cast iron and looks like the one on the left. I will have to check how far out the pto shaft sticks out from the tractor. It would still be the original pto shaft. The previous owner did not repair anything at all. He ran them into the ground and then replaced the tractor with another one.
TY
SDE
