9N Polarity Backwards Electronic ignition
JAFord9N
PostPosted: Sun Jun 07, 2020 5:34 pm    Post subject: 9N Polarity Backwards Electronic ignition Reply to specific post Reply with quote
Any input would be greatly appreciated and may save me some time and $. I was converting my early 9N from 6v pos ground to 12v neg ground, and installed new electronic ignition (12v coil). I clearly wasnt paying attention and hooked up the batt as pos ground and let the smoke out of the alternator, which I assume now is fried. I also fried the starter switch but I touched off the + lead on the starter using a jumper cable and will turn over. I couldn;t get it to fire that way so I pulled a plug to check spark and - no spark. Finally - my question is, do you think I fried the 12v distributor and/or the electronic ignition as well? I checked continuity and resistance across the coil and got about 2.4 ohms which I assume is good, but not sure.
David G
PostPosted: Sun Jun 07, 2020 6:00 pm    Post subject: Re: 9N Polarity Backwards Electronic ignition Reply to specific post Reply with quote
EI is probably toast too.
R Geiger
PostPosted: Sun Jun 07, 2020 6:08 pm    Post subject: Re: 9N Polarity Backwards Electronic ignition Reply to specific post Reply with quote
I doubt that you fried the starter switch, if you have the orginial one. it would not care what the polarity is.
JAFord9N
PostPosted: Sun Jun 07, 2020 6:15 pm    Post subject: Re: 9N Polarity Backwards Electronic ignition Reply to specific post Reply with quote
Thanks guys, not the news I was hoping for, but the news I expected. Know of any ways to check the EI before I throw the points back in it? Regular old points will work with a new 12v coil/system right?
JMOR
PostPosted: Sun Jun 07, 2020 7:35 pm    Post subject: Re: 9N Polarity Backwards Electronic ignition Reply to specific post Reply with quote
JAFord9N wrote:
(quoted from post at 22:15:23 06/07/20) Thanks guys, not the news I was hoping for, but the news I expected. Know of any ways to check the EI before I throw the points back in it? Regular old points will work with a new 12v coil/system right?
JAFord9N
PostPosted: Sun Jun 07, 2020 8:10 pm    Post subject: Re: 9N Polarity Backwards Electronic ignition Reply to specific post Reply with quote
Great thank you, ill try that
Jim L WA
PostPosted: Mon Jun 08, 2020 6:58 am    Post subject: Re: 9N Polarity Backwards Electronic ignition Reply to specific post Reply with quote
To answer your question, yes the points will work just fine with 12 volts.
