Ford 8N rebuilds
sabujur
PostPosted: Sat Jun 13, 2020 7:50 am    Post subject: Ford 8N rebuilds Reply to specific post Reply with quote
I'm rebuilding my Ford 8N engine, and saw they have 3, and 4 ring pistons for sale. I haven't pulled my engine yet, does anyone know if there is an advantage of one ring style over the other? thanks.
TheOldHokie
PostPosted: Sat Jun 13, 2020 8:18 am    Post subject: Re: Ford 8N rebuilds Reply to specific post Reply with quote
sabujur wrote:
(quoted from post at 11:50:12 06/13/20) I'm rebuilding my Ford 8N engine, and saw they have 3, and 4 ring pistons for sale. I haven't pulled my engine yet, does anyone know if there is an advantage of one ring style over the other? thanks.
Ford used both. Started OUT with four and switched to three. I think that pretty much indicates what their engineers thought.
TOH
Jim WI
PostPosted: Sat Jun 13, 2020 2:34 pm    Post subject: Re: Ford 8N rebuilds Reply to specific post Reply with quote
TheOldHokie wrote:
(quoted from post at 11:18:41 06/13/20)
TOH
Either that or the bean-counters. At this remove it's hard to tell.
mhb@ufe
PostPosted: Sat Jun 13, 2020 2:59 pm    Post subject: Re: Ford 8N rebuilds Reply to specific post Reply with quote
The 4 ring piston has an additional oil ring near the bottom of the piston. Some believe this wipes the cylinders down too much causing excessive wear from lack of lubrication between the pistons and cylinder walls. Some say that is the reason Ford went to the 3 ring piston but I can't verify that.
Mark
TheOldHokie
PostPosted: Sat Jun 13, 2020 4:30 pm    Post subject: Re: Ford 8N rebuilds Reply to specific post Reply with quote
CVPost-mhb@ufe wrote:
(quoted from post at 18:59:49 06/13/20) The 4 ring piston has an additional oil ring near the bottom of the piston. Some believe this wipes the cylinders down too much causing excessive wear from lack of lubrication between the pistons and cylinder walls. Some say that is the reason Ford went to the 3 ring piston but I can't verify that.
Mark
Some also believe it was because of the the switch from steel to cast iron sleeves.
Nobody really knows but I think it's safe to say 3 ring pistons are the modern engineering standard.
TOH
sabujur
PostPosted: Sun Jun 14, 2020 7:24 am    Post subject: Re: Ford 8N rebuilds Reply to specific post Reply with quote
Thanks, I think I'll order the 3 ring pistons.
