1945 Ford 2N Original Starter Switch busted off.
BRYANODOUGHERTY
PostPosted: Wed Jun 17, 2020 8:16 am    Post subject: 1945 Ford 2N Original Starter Switch busted off. Reply to specific post Reply with quote
I just purchased a 1945 Ford 2N that has been converted to a 12 V system. The original starter button (Jst in front of the gear shift lever) was previously broken and someone tried to braize it back on. I plan on using JB Weld since it is useless now. What are the holes in the sides? Is it OK to seal the holes also?
Tony in SD
PostPosted: Wed Jun 17, 2020 8:24 am    Post subject: Re: 1945 Ford 2N Original Starter Switch busted off. Reply to specific post Reply with quote
Not sure what holes you are talking about. Picture of the holes would be a good addition to this conversation.
Jim L WA
PostPosted: Wed Jun 17, 2020 8:39 am    Post subject: Re: 1945 Ford 2N Original Starter Switch busted off. Reply to specific post Reply with quote
I have a '44 2N and I don't know what holes you are referring to either. Unless you are talking about the holes where the start switch itself is mounted to under the battery. I'm curious, how do you start the tractor now?
shaun wallace
PostPosted: Wed Jun 17, 2020 9:12 am    Post subject: Re: 1945 Ford 2N Original Starter Switch busted off. Reply to specific post Reply with quote
Think meaning where pin for diecast fork pivioted on. Sounds like its missing too.
BRYANODOUGHERTY
PostPosted: Wed Jun 17, 2020 9:25 am    Post subject: Re: 1945 Ford 2N Original Starter Switch busted off. Reply to specific post Reply with quote
What is the pin for diecast fork for? Having problems upload a picture onto this site. Still trying
R Geiger
PostPosted: Wed Jun 17, 2020 9:34 am    Post subject: Re: 1945 Ford 2N Original Starter Switch busted off. Reply to specific post Reply with quote
for some strange unknown reason you have to make a few posts before you are allowed to post photos!
JMOR
PostPosted: Wed Jun 17, 2020 11:15 am    Post subject: Re: 1945 Ford 2N Original Starter Switch busted off. Reply to specific post Reply with quote
R Geiger wrote:
(quoted from post at 13:34:38 06/17/20) for some strange unknown reason you have to make a few posts before you are allowed to post photos!
The holes are probably for the pin mentioned above.
BRYANODOUGHERTY
PostPosted: Wed Jun 17, 2020 6:54 pm    Post subject: Re: 1945 Ford 2N Original Starter Switch busted off. Reply to specific post Reply with quote
That answers it. It is a pin hole that needs to be sealed also. Thank you so much for the pic!
Tim PloughNman Daley
PostPosted: Thu Jun 18, 2020 2:12 am    Post subject: Re: 1945 Ford 2N Original Starter Switch busted off. Reply to specific post Reply with quote
Carpenter makes and sells an exact-as-original pushbutton starter switch, 9N-11450-B
Tim Daley(MI)
