1020 and 37 loader Update
Hotflashjr
PostPosted: Mon Jun 22, 2020 1:16 pm    Post subject: 1020 and 37 loader Update Reply to specific post Reply with quote
So I bought the loader. After looking over the loader valve it is a
Gresen SPK valve that has down pressure for the main cylinders. I
took off the cap where the closed center plug should be and it is an
open center plug. So I learned Gresen is now Parker-Gresen and I
think finding the closed center plug is not possible. I think a new
valve is in order. I believe the one Briar Hill Britney’s poster would be
the correct valve and work fine.
I included a picture of the valve as well as the current set up for the
home brew hydraulic outlets. Can I add a T fitting in the current set
up to hook up the loader and keep the hydraulic outlets?
Tx Jim
PostPosted: Mon Jun 22, 2020 1:33 pm    Post subject: Re: 1020 and 37 loader Update Reply to specific post Reply with quote
Yes you can add a tee to each hose connection shown in photo below to attach pressure/return for FEL control valve.
Hotflashjr
PostPosted: Mon Jun 22, 2020 2:02 pm    Post subject: Re: 1020 and 37 loader Update Reply to specific post Reply with quote
Boy those pictures are horrible. They do not look that bad on my phone at all. Return line will go to the filter housing correct? Thanks!
buickanddeere
PostPosted: Mon Jun 22, 2020 7:10 pm    Post subject: Re: 1020 and 37 loader Update Reply to specific post Reply with quote
Could be lucky and the manufacturer change names but keep making the same valve ?
Tx Jim
PostPosted: Tue Jun 23, 2020 2:07 am    Post subject: Re: 1020 and 37 loader Update Reply to specific post Reply with quote
CVPost-hotflashjr wrote:
(quoted from post at 17:02:02 06/22/20) Boy those pictures are horrible. They do not look that bad on my phone at all. Return line will go to the filter housing correct? Thanks!
Yes FEL control valve return line should be teed into line attached to ported filter cover on your tractor.
