4240 Jd
Bruce SEKs
PostPosted: Fri Jun 26, 2020 6:41 pm    Post subject: 4240 Jd Reply to specific post Reply with quote
My charging system on my 4240 is not working right. Amp meter shows overcharge and then neutral charge then stops working. I have changed the alternator twice and still having the same problem..I ran the batteries dead. I hooked a wire straight from the alternator to one of the batteries and the system worked for awhile at least kept the AC working. It acts like a wire is broken. This morning though the system charged for awhile and quit. Is there a regulator or something in the system that quits working after a short time? I really know very little about electric
matthies
PostPosted: Fri Jun 26, 2020 7:03 pm    Post subject: Re: 4240 Jd Reply to specific post Reply with quote
There was problems with the small wire coming from the cab to the two wire plug of the alternator. Deere made a kit to fix the problem. See what the wire looks like and check for 12 volts. I am thinking it was a resistor wire.
FWB in SK
PostPosted: Fri Jun 26, 2020 8:25 pm    Post subject: Re: 4240 Jd Reply to specific post Reply with quote
Sometimes the wire is broke on the curve in the wire close to the alternator.What mathies wrote fixed neghbors same problem.
wore out
PostPosted: Fri Jun 26, 2020 9:58 pm    Post subject: Re: 4240 Jd Reply to specific post Reply with quote
CVPost-matthies wrote:
(quoted from post at 20:03:06 06/26/20) There was problems with the small wire coming from the cab to the two wire plug of the alternator. Deere made a kit to fix the problem. See what the wire looks like and check for 12 volts. I am thinking it was a resistor wire.
The original setup was a single strand of resistance (Nichrome) wire, very brittle stuff and it would break inside the insulation causing the alternator not to "excite" and begin to charge.
DEERE's "fix"was a $$$ separate little harness with a diode plugged into it, AR90840 @ some $60.
You can do the same thing with a $0.50 diode (1N5408 or similar) and a few feet of 16GA wire.
Note the resistance wire from Terminal 1 on the alternator to "3" in the bulkhead connector, that's the wire that fatigues and breaks.
The complete length, from the terminal in the bulkhead connector to the #1 terminal on the alternator can be replaced with a length of #16 automotive wire with a diode spliced into it.
The end of the diode with the white band is the cathode and goes towards the alternator.
This is the same thing the $$$ DEERE replacement harness does.
