Mid-Western Industries Model 802 Loader on 8N
Bjorn Lysne
PostPosted: Wed Jul 08, 2020 2:37 pm    Post subject: Mid-Western Industries Model 802 Loader on 8N Reply to specific post Reply with quote
Does anybody have an idea of what I can do to replace the hydraulic cylinder on this loader? I broke my right cylinder and can't, for the life of me, find a replacement. YT would not allow me to post a picture, but its the top assembly that screws on to the main tube of the cylinder.
Thank you-
Bjorn
R Geiger
PostPosted: Wed Jul 08, 2020 2:53 pm    Post subject: Re: Mid-Western Industries Model 802 Loader on 8N Reply to specific post Reply with quote
[quote="Bjorn Lysne"](reply to post at 16:37:32 07/08/20) [/qhttps://www.surpluscenter.com/Hydraulics/Hydraulic-Cylinders/Double-Acting-Hydraulic-Cylinders/uote]
might try here
wore out
PostPosted: Wed Jul 08, 2020 8:52 pm    Post subject: Re: Mid-Western Industries Model 802 Loader on 8N Reply to specific post Reply with quote
Sounds like you need the cast iron "gland" that seals to the barrel and contains the rod seals.
Likely, a nearby welding/machine shop could make you one out of steel, it's been done many times.
Issue would be cost, if you're lucky you might find a semi-retired guy that has a little shop to make one for you reasonably.
Also, it's possible the old part could be welded or brazed.
TheOldHokie
PostPosted: Thu Jul 09, 2020 4:57 am    Post subject: Re: Mid-Western Industries Model 802 Loader on 8N Reply to specific post Reply with quote
CVPost-wore out wrote:
(quoted from post at 00:52:13 07/09/20) Sounds like you need the cast iron "gland" that seals to the barrel and contains the rod seals.
Making a replacement is not super difficult. IIRC I charged $65 for making this one 12 years ago. The price would be a good bit more today.
TOH
Bjorn Lysne
PostPosted: Thu Jul 09, 2020 6:15 am    Post subject: Re: Mid-Western Industries Model 802 Loader on 8N Reply to specific post Reply with quote
(quoted from post at 21:52:13 07/08/20) Sounds like you need the cast iron "gland" that seals to the barrel and contains the rod seals.
Thank you for the suggestions. The first shop I took it to wanted $600 to remake the gland. Waiting on second shop's opinion. He mentioned the possibility of TIG welding with a nickle rod as a possible option.
TheOldHokie
PostPosted: Thu Jul 09, 2020 2:49 pm    Post subject: Re: Mid-Western Industries Model 802 Loader on 8N Reply to specific post Reply with quote
Bjorn Lysne wrote:
(quoted from post at 10:15:25 07/09/20)
I have known for a while I work way to cheap. A new replacement cylinder is starting to look very economical. Not to mention awfully easy.
TOH
Caryc
PostPosted: Sat Jul 11, 2020 1:57 pm    Post subject: Re: Mid-Western Industries Model 802 Loader on 8N Reply to specific post Reply with quote
TheOldHokie wrote:
(quoted from post at 15:49:21 07/09/20)
TOH
At $600 for a new gland, a new cylinder was also my first thought.
