chopped hay for horses
Gobind
PostPosted: Wed Dec 27, 2006 5:33 am    Post subject: chopped hay for horses Reply to specific post Reply with quote
When we put hay outdoors in those racks with the tub underneath our horses drag alot of it onto the ground and trample much of it into the dirt/mud and then of course do not eat it. When we put hay into a trough they drag all of it onto the ground. I hate to see all that good hay go to waste! Been thinking about chopping the hay so that the beasties don't have to shake it to get the "properly" sized mouthful. Anyone have any experience feeding chopped hay to horses? What was your experience and what equipment did you use? Thanks.
MyrlfromPA
PostPosted: Wed Dec 27, 2006 5:55 am    Post subject: Re: chopped hay for horses Reply to specific post Reply with quote
First off salt your hay when you put it away and second never never feed hay to horses above ground level. build a hayrack against the fence that is about two feet tall with room for them to throw it around a little. That will pretty much solve your problem.
Larry NE IL
PostPosted: Wed Dec 27, 2006 9:45 am    Post subject: Re: chopped hay for horses Reply to specific post Reply with quote
I feed my horses mostly alfalfa, and feed in tubs. If I feed them too much they throw a lot out and I believe they are shaking to get the leaves on the bottom of the tub.
You might try cutting back their quantity some and they will eat more of what you put out.
Mulesandheelers
PostPosted: Wed Dec 27, 2006 7:05 pm    Post subject: Re: chopped hay for horses Reply to specific post Reply with quote
The least amount of waste I've found is to feed in a clean
pasture, a single flake at least - a horse length and a half apart or futher.
A horse will high-grade it, spread it some, then come back and finish it [ifen you're not over feeding].
jwal10
PostPosted: Wed Dec 27, 2006 8:15 pm    Post subject: Re: chopped hay for horses Reply to specific post Reply with quote
You need to be carful with chopped hay for horses. If it is a little dusty to start with, either dirt, or finely chopped leaves, it can cause problems with breathing when a horse inhales it. WE put most of our hay up using silage equipment. We chopped it then used blower to fill barn. We didn't feed it to working horses because when breathing hard they would develop a wheeze.I don't know of anything that would chop hay coarse enough and keep leaves intact for feeding.
Sid
PostPosted: Wed Dec 27, 2006 8:59 pm    Post subject: Re: chopped hay for horses Reply to specific post Reply with quote
Why salt hay to keep horses from wasting it?
hayray
PostPosted: Thu Dec 28, 2006 5:13 am    Post subject: Re: chopped hay for horses Reply to specific post Reply with quote
I have a friend that has a round baler with slicers on it and it makes real small pieces that the animals cows and horses eat better. One thing is that those racks cause a lot of waste on the ground, it is better to feed on the ground in a round bale feeder and feed less hay at a time will also help. I don't see why you could not feed chopped hay, the dehydrated hay cubes are choppedd hay and that works real well on horses, just make sure during the process that ou don't loose the leaves.
MyrlfromPA
PostPosted: Fri Dec 29, 2006 4:56 am    Post subject: Re: chopped hay for horses Reply to specific post Reply with quote
The salt is a preservitive and keeps the hay fresher and they dont seem to pick through it as much. It also draws out all the moisture and moisture is what causes dust. Also dont you like a little salt on your food?
Rexalot
PostPosted: Mon Jan 08, 2007 11:54 am    Post subject: Re: chopped hay for horses Reply to specific post Reply with quote
Ok, what kind of salt are you using and where are you finding it in bulk.
I just keep picturing standing on top of the hay rack sprinkling it out of a salt shaker....
Iowa Jim
PostPosted: Mon Jan 08, 2007 2:08 pm    Post subject: Re: chopped hay for horses Reply to specific post Reply with quote
This is another old wives tale that has been shown not to work in research settings. It would be better to practice good management and put up the hay at the correct moisture OR use a proven preservative method that applies presrvative evenly to the entire crop.
Jim
Post new topic    Yesterday's Tractors Forum Index -> Using Your Tractor & Crop Talk All times are GMT - 8 Hours
