alfalfa
jc mini
PostPosted: Thu Dec 28, 2006 10:32 am    Post subject: alfalfa Reply to specific post Reply with quote
I am new to this hay stuff and I have A field of
alfalfa how do I know when its ready to cut? how
short can I cut? and When should I get my last cut?
Also how do you determine when the moisture is right to bale?
paul
PostPosted: Thu Dec 28, 2006 7:49 pm    Post subject: Re: alfalfa Reply to specific post Reply with quote
The earlier you cut, the more protien but the less tons per cutting. If you want to feed rabbits or dairy, cut before you see any blossoms.
If you are feeding cattle or meat animals, you might want more roughage/tons per cutting, and want to cut at 10% blooms. Hate to get later than that. (You will, when it rains.....)
Can lay a mower bar on the ground & cut, comes back fine. Shortness isn't an issue 'here'.
You shouldn't cut alfalfa between 200 & 600 growing degree days before the killing frost.
What does that mean you ask? :) During it's heavy growing period alfalfa pulls it's roots about empty of nutrition. Really bad to cut it off then & let it freeze up, empty for the winter. Very easy to winter kill then.
So, give it 20-30 days to grow be4 it freezes. However, once it freezes, you _can_ harvest that last cutting. But you'd like some snow cover, & short cut doesn't leave much snow cover. Depends where you are, for snow & how cold is cold.
Dairy folks here want 4 cuttings, high in protien. Cattle folks take 3 cuttings, little less protien. Both get about the same tons maybe. More protien for the dairy, less machine/labor costs for meat. You can play with alfalfa a bit.
--->Paul
Larry NE IL
PostPosted: Fri Dec 29, 2006 9:49 pm    Post subject: Re: alfalfa Reply to specific post Reply with quote
Aside from the excellent answers from Paul, the easiest way to test for dryness is to grab a handful and twist it about 3 times, if the stems break, it's probably right to bale. Test it like that in more than one location and from the bottom of your swaths.
Post new topic    Yesterday's Tractors Forum Index -> Using Your Tractor & Crop Talk All times are GMT - 8 Hours
