Graphite Rods and Brazing
Goto page 1, 2  Next
WeirdDeere
PostPosted: Tue Jul 14, 2020 3:04 pm    Post subject: Graphite Rods and Brazing Reply to specific post Reply with quote
I have a HEAVY cast axle with a blown out pivot pin whole. Factory is 1 3/8, it's now pushing 1 3/4
I'm debating my options. If I had a mill I'd do that immediately. I'm just trying to see how I can get it done myself without going out for it.
Could I put a graphite rod in the hole of the proper size then build the wear up with brazing? I know it works with welding, I would assume the same with braze?
Like these:
https://www.mcmaster.com/graphite-rods/
Thanks for any tips, even other ideas,
Brandon
SVcummins
PostPosted: Tue Jul 14, 2020 3:27 pm    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
The first thing I’d do is buy a new grease gun
WeirdDeere
PostPosted: Tue Jul 14, 2020 3:30 pm    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
Tell the guys that beat it to death the 50 years before me. Most of that excessive grease is probably from me. The kingpins are just as bad, none of the fittings would take grease until I messed with it with penetrating oil and a torch...but too late.
Brandon
Phonostud
PostPosted: Tue Jul 14, 2020 3:31 pm    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
Greetings Brandon: You might be able to solder in a piece of thin wall steel tubeing, or weld it in place. I have arc welded grey iron castings several times, and have had the best luck with 6000 series electrodes. The nickle alloy rods made for grey iron
usually didn't work as well. One part couldn't be welded with either one. Bad chemistry probably. Good Luck!
WeirdDeere
PostPosted: Tue Jul 14, 2020 3:43 pm    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
You might be onto something.
1 1/4 pipe is 1.380 ID
The pin is 1.375 OD, so it'd be a good match
Thank you, you're getting my brain going, my main concern was how to get a decent hole after adding material!!!
Brandon
T.R.K.
PostPosted: Tue Jul 14, 2020 5:08 pm    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
I think you could. There was a series of videos by 'turn right machine works' on Youtube where the author built up a lathe cross slide using graphite or similar cores for shaping his brazing. They were posted on Youtube just a few weeks ago.
DoubleO7
PostPosted: Tue Jul 14, 2020 5:23 pm    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
CVPost-Weirddeere wrote:
(quoted from post at 20:43:39 07/14/20) You might be onto something.
Brandon
Without a mill, how are you going to get a 1.66" dia. Hole for the 1-1/4" pipe exactly where it needs to be? Will the 1 .38 inside dia. Of the pipe be good enough? Common ERW pipe will have a light weld seam inside. Might have to use seamless.
WeirdDeere
PostPosted: Tue Jul 14, 2020 7:07 pm    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
The diameter should be doable, even if it needs a little finessing. Die grinder might clean up any internal welding.
Locating the pipe would be tough and I'm thinking up solutions, maybe welding it onto a plate on one side that will locate it while I do whatever else in the mess that is the original bore. I think braze but not sure. Then cut it off when done.
I'm thinking out loud.
Will it be a super precise fix, no, but a LOT better then how it is now and should be durable to last for my hobby use
Brandon
WeirdDeere
PostPosted: Tue Jul 14, 2020 7:08 pm    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
I know his videos but missed those, I will look, THANKS
Brandon
baldy347
PostPosted: Wed Jul 15, 2020 3:00 am    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
A guy posting as fireball tool has a video on removing the inside weld seam that seems to work well.
WeirdDeere
PostPosted: Wed Jul 15, 2020 6:56 am    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
I know the poster you're talking about but had missed that one. Very interesting idea, though overkill for the one pipe I might do haha
Brandon
DoubleO7
PostPosted: Wed Jul 15, 2020 7:08 am    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
How long does the pipe/sleeve need to be?
WeirdDeere
PostPosted: Wed Jul 15, 2020 7:20 am    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
Keep forgetting to lay a tape on it but probably about 4 inches
Brandon
Ragnarok
PostPosted: Wed Jul 15, 2020 9:11 am    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
I've taken stuff like that to the local machine shop and had it bored and sleeved back to size...helps if ths shop has a good center pin to measure
WeirdDeere
PostPosted: Wed Jul 15, 2020 9:16 am    Post subject: Re: Graphite Rods and Brazing Reply to specific post Reply with quote
That would be my normal route but I am out of a job and trying not to be stupid with money.
And it ANNOYS me that I don't have access to a mill to do it myself. I want the practice.
Brandon
Goto page 1, 2  Next
Page 1 of 2
