Harry Ferguson TO 30 with a frontend loader
MFTO30.mills
PostPosted: Thu Aug 06, 2020 7:46 pm    Post subject: Harry Ferguson TO 30 with a frontend loader Reply to specific post Reply with quote
Any assistance will be greatly appreciated. I have just bought a Harry Ferguson TO30 with a frontend loader
The tractor itself, other than its missing the hood is in what I would consider better than average condition everything works as it should, seems to run strong
Biggest problem is that the front pump , shaft and harmonic balancer pulley adapter is missing and I need a replacement
Tom H.
PostPosted: Fri Aug 07, 2020 3:12 am    Post subject: Re: Harry Ferguson TO 30 with a frontend loader Reply to specific post Reply with quote
Congratulations, you have a very good tractor to work with. Your parts are available here on the parts link top of the page,”Ferguson”, and look at the
hydraulic parts there, also Steiner tractor is a great source.
MFTO30.mills
PostPosted: Fri Aug 07, 2020 10:34 pm    Post subject: Re: Harry Ferguson TO 30 with a frontend loader Reply to specific post Reply with quote
CVPost-Tom h. wrote:
(quoted from post at 04:12:29 08/07/20) Congratulations, you have a very good tractor to work with. Your parts are available here on the parts link top of the page,"Ferguson", and look at the
Thank you for your reply, to be honest I'm still unsure of specifically the correct part due to there being missing completely.
Any chances you might know the exact patt numbers for those three items ?
Bruce(OR)
PostPosted: Sat Aug 08, 2020 5:00 am    Post subject: Re: Harry Ferguson TO 30 with a frontend loader Reply to specific post Reply with quote
Can't do that. FEL was aftermarket add on. Who did it? PO or dealer? That actually would not make much difference at this age. Your best
bet might be a trip to the local Case or New Holland dealer and get some part numbers and a pic. You should at least buy the hex drive
shaft and the pulley mount from them for the troubles of looking it all up for you.
Be glad you have a TO-30. The loader front pulley might still be in production. The TO-20 pulley is totally obsolete.
1753729M91 is your hub mount number and them comes the Part No: L78-13 shaft mount. Beyond that is the shaft and good luck on that as well
as the pump itself.
Go over to the 8N Ford board and see what you get for info. Ebay might be your friend if someone is parting out a machine.
Surplus center hydraulics might also be your friend.
I haven't had to look for this stuff for many years. Now I have two machines with a FEL and another two machines without FEL.
Then a few machines. . . .
Bruce(OR)
PostPosted: Sat Aug 08, 2020 8:29 am    Post subject: Re: Harry Ferguson TO 30 with a frontend loader Reply to specific post Reply with quote
Here is another part of your set up. Hope your fab skills are snuff. If not, then deep pockets will follow.
Untitled URL Link
