Coil Continuity 8N front Mount
Steven Kotula
PostPosted: Tue Aug 11, 2020 7:09 am    Post subject: Coil Continuity 8N front Mount Reply to specific post Reply with quote
Have two "spare coils" for my 8N front mounted distributor. I get continuity when I connect top terminal to the "pig tail" on both but nothing on either when I connect top terminal with front tab. Are both of these coils bad? thank you.
Bruce (VA)
PostPosted: Tue Aug 11, 2020 7:12 am    Post subject: Re: Coil Continuity 8N front Mount Reply to specific post Reply with quote
check your meter scale.
primary should be 2 to 2.5 ohms. Maybe less if 6v.
Secondary ( post to tab) should be 7 to 8K ohms.
75 Tips
JMOR
CVPost-Steven Kotula wrote:
(quoted from post at 11:09:29 08/11/20) Have two "spare coils" for my 8N front mounted distributor. I get continuity when I connect top terminal to the "pig tail" on both but nothing on either when I connect top terminal with front tab. Are both of these coils bad? thank you.
big question is, what is continuity in your mind? On high voltage winding, you are looking at 15,000 Ohms, not one or two Ohms.
