861 Hydraulics
usmck405
PostPosted: Mon Aug 10, 2020 7:42 am    Post subject: 861 Hydraulics Reply to specific post Reply with quote
I currently have to have my hydraulics lever all the way to the top to be able to get the front of my bushhog off the ground. While it holds it there it will very slowly fall and then bump back up over and over again.
Any ideas as to what is going on? I would rather not have to rebuild or replace the hydraulic cylinder if I don't have to.
Husker 50 8n
PostPosted: Mon Aug 10, 2020 11:54 am    Post subject: Re: 861 Hydraulics Reply to specific post Reply with quote
Most likely your cylinder does need rebuilt. And check the cam follower pin while you have it apart. If nothing happens until you have the
lever pulled almost all the way up, your pin may have a pretty deep groove worn in it. Watch a video, not really too bad to work on. Make
sure you don't lose any orings and have a new gasket for the cover.
usmck405
PostPosted: Mon Aug 10, 2020 11:58 am    Post subject: Re: 861 Hydraulics Reply to specific post Reply with quote
CVPost-Husker 50 8n wrote:
(quoted from post at 14:54:27 08/10/20) Most likely your cylinder does need rebuilt. And check the cam follower pin while you have it apart. If nothing happens until you have the
Yes! I know just the video to help me with that. Thank you for the help!
