Author |
Message |
LittleMackinawFarmall Guest
Posted: Sun Jun 10, 2007 9:33 pm Post subject: 560 set ups? |
So if we do the compression test find a weak cylinder anyone have any suggestions for setups that are still farmable when they are done? Pulling farm stock but still want to pull a wagon, plow or run a 10 or 12" auger on occasion |
Back to top |
ChadS Guest
Posted: Mon Jun 11, 2007 5:54 am Post subject: Re: 560 set ups? |
Lets say you do take it apart, pull the pistons out, and if things look really good, you might get away with a new rings with the same pistons. If they dont look good, just go with a stock sleeve and piston kit. If its blowing fuel out the exhaust, then Id agree with the post below and needs to be burned out with a long work period. But if its truly engine oil,, its leaking into the cyl somewhere,, either bad rings, or valve guides. Just sounds like it needs to be looked at closer,,, that way you know what you have exactly and can eliminate any possible problems. I got a 93 7.3 ford, that started running rough,, smoked white and blackish out the pipe, rough idle, had the pump rebuilt, and it ran alot better,, but, about 500 miles later, it popped the headgaskets. New headgaskets and a good cleaning, and it runs with dependability. But, I belive the problem started with my 7.3 was the headgasket starting to go. Back to the 560,,,, there is only 4 bolts holding 300+psi of cyl pressure on each cyl,,, its not much to hold em down,, it will hold for a while,,, but eventually they pop. They are famous for it. But, can be assembled to last a while longer,,, JMHO. Chad |
Back to top |
Posted: Mon Jun 11, 2007 8:27 am Post subject: Re: 560 set ups? |
amazing only four bolts huh, well am gonna start digging a little deeper into this there was a couple beautiful D's at the pull in Tremont IL on saturday and inspired me a tad to get busy problem will be the wife tapping her foot on the super M that she pulls now she wants a shiny one too....will appreciate any help and tips on the 560 as I get moving on this project have read alot of your posts Chad with great enthusiasm. |
Back to top |
Jim Johnson Guest
Posted: Mon Jun 11, 2007 7:53 pm Post subject: Re: 560 set ups? |
Yeah tear er' down, hurry up, don't try those simple fixes. Be a man spend some money ol' Chads will take it, hurry up. Do it now. |
Back to top |
ChadS Guest
Posted: Tue Jun 12, 2007 5:36 am Post subject: Hey Jimmy! |
Ever see one catch fire, while trying to "burn" one out? Bout burned a 3010 JD to the ground the other day following the burn out method. Caught the oil on fire that had splattered out the exhaust pipe from all the exxcessive heat it takes to burn all the trash. Most of us have to WORK on em and still use em while we PLAY! Im just along for the ride. Something to think about there, and this is a young fella telling an elder,, "When you point a finger, you have 3 still pointing back at ya" so keep that in mind when you talk about others. On the money issue,,, put your money where your mouth is, cause the only way I want your money is to take it from you on the track. We got a BIG pull comming up in July, and you can do your best in front of a crowd of 30,000+ Hook up to a real sled. Talk to you soon. Chad |
Back to top |
