Author |
Message |
Ed H.-OH Regular
Posted: Tue Aug 04, 2020 12:36 pm Post subject: Re: Sherman backhoe on TO30 |
Hello, if you look at the rear of the back of its kind of self-
explanatory, slide into that drawbar hitch underneath the PTO I
got two bars welded solid in there so it can't move ,and ties into
the big top pin on the rear end housing... been working very well
for years hi, any other questions feel free I would be glad to
help....Ed |
Back to top |
paul25g Regular
Posted: Thu Aug 06, 2020 3:52 am Post subject: Re: Sherman backhoe on TO30 |
Thanks very much Ed!
One other quick question. Do you know if a 54B like yours was originally meant to attach to a subframe? My understanding is that the model 54C did use a subframe, but I'm just not sure about a 54B.
Thanks again, I appreciate your help!
Paul |
Back to top |
Ed H.-OH Regular
Posted: Thu Aug 06, 2020 12:01 pm Post subject: Re: Sherman backhoe on TO30 |
Hello, glad to help, mine it came just like it is in the picture,
if there was a subframe on it I never seen it... mine was in the
scrap behind a farm equipment dealership they didn't think it was
worth saving... it was more work to restore it than it was
actually worth it but I wanted the right age group to match my
tractor... good luck with yours , it is a good strong backhoe and
I put a remote clutch on mine so I can move the tractor sitting in
the backhoe seat to make up for the short boom.. been using it off
and on for 18 years.. that was made by Wayne Roy in Michigan and
they actually patent and invented the backhoe concept |
Back to top |
Manchesterjake New User
Posted: Sun Oct 11, 2020 10:43 am Post subject: Re: Sherman backhoe on TO30 |
What is the specific hydraulic pump you have powering this backhoe? |
Back to top |
8NChris Long Time User
Posted: Sun Oct 11, 2020 1:24 pm Post subject: Re: Sherman backhoe on TO30 |
CVPost-Manchesterjake wrote: | (quoted from post at 11:43:54 10/11/20) What is the specific hydraulic pump you have powering this backhoe? | Here is mine in it's worn glory.
Ed. H, I see where your mounting is different due to the fast hitch modification. Do you use a remote pump different than the PTO mounted Hydreco? |
Back to top |
Posted: Sun Oct 11, 2020 1:28 pm Post subject: Re: Sherman backhoe on TO30 |
8NChris wrote: | (quoted from post at 14:24:06 10/11/20) CVPost-Manchesterjake wrote: | (quoted from post at 11:43:54 10/11/20) What is the specific hydraulic pump you have powering this backhoe? | Here is mine in it's worn glory.
Ed. H, I see where your mounting is different due to the fast hitch modification. Do you use a remote pump different than the PTO mounted Hydreco? | Forgot the photos.
Back to top |
