John Deere 2040 Front end loader
gapfast83
PostPosted: Thu Sep 24, 2020 4:38 pm    Post subject: John Deere 2040 Front end loader Reply to specific post Reply with quote
hello, new to the group. I Have a 83 2040...I think
Ive been searching high and low for loaders local. found several I think would work with a bit of fabrication. Im really not wanting a project. In my searching: 143. 145. 175?. 210. 520. 146. 148. 158? Am I missing any or confused on these?
Im not even sure of what type hydralics I have.
Has anyone documented a "easy" other brand that fits?
thanks
Phil
JDIH
PostPosted: Thu Sep 24, 2020 6:31 pm    Post subject: Re: John Deere 2040 Front end loader Reply to specific post Reply with quote
You may want to post this on the "John Deere" section of this forum. Theres some really sharp guys there that I'm sure can answer all of your questions.
Tx Jim
PostPosted: Fri Sep 25, 2020 1:50 am    Post subject: Re: John Deere 2040 Front end loader Reply to specific post Reply with quote
Welcome to YT
JD 148 & 158 FEL weren't designed to fit JD 2040 tractors.
Does your 2040 have a 3 or 4 cyl engine?
gapfast83
PostPosted: Fri Sep 25, 2020 2:28 am    Post subject: Re: John Deere 2040 Front end loader Reply to specific post Reply with quote
Tx Jim wrote:
(quoted from post at 02:50:14 09/25/20)
Welcome to YT
Thanks Jim, this is info I need. I will mark those off my list. Mine is the 3cyl engine.
Tx Jim
PostPosted: Fri Sep 25, 2020 3:35 am    Post subject: Re: John Deere 2040 Front end loader Reply to specific post Reply with quote
You're welcome
According to serial chart I located JD 2040 with 3 cyl engine were built '76-'82 not '83. JD 2040 with 3 cyl engine built before serial # 266750 would have open center hyd & in 1978 changed to closed center hyd's. This info is very important when installing a FEL utilizing a ind control valve.
gapfast83
PostPosted: Fri Sep 25, 2020 6:38 am    Post subject: Re: John Deere 2040 Front end loader Reply to specific post Reply with quote
Awesome info Jim!! Thank you. Is this chart something you can share?
Tx Jim
PostPosted: Fri Sep 25, 2020 7:21 am    Post subject: Re: John Deere 2040 Front end loader Reply to specific post Reply with quote
You're welcome.
Although the OC/CC hyd info is available on Tractordata I'm unaware of a chart. Plus I sold ""new 2040's""
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
