Author |
Message |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 95989 Location: Lake of the Ozarks area of MO
Posted: Mon Sep 21, 2020 10:39 am Post subject: %$$ hay rake teeth |
So I was out raking hay when all at once the rake stopped spinning. 3 rake teeth bent and got hung in the round loop bar. The hay is not all that thick to boot |
Back to top |
RayP(MI) Tractor Guru
Posted: Mon Sep 21, 2020 11:02 am Post subject: Re: %$$ hay rake teeth |
Is your rake colliding with the ground?
Teeth hitting g the ground can get damaged easily. Especially teeth like you get from the cheaper sources like TSC. |
Back to top |
old Tractor Guru
Posted: Mon Sep 21, 2020 11:12 am Post subject: Re: %$$ hay rake teeth |
Only place I have to get them is the farm an home places. One of the teeth is so bad the spring part is unwound and now about twice as long as it should be |
Back to top |
Hayfarmer Tractor Expert
Posted: Mon Sep 21, 2020 11:48 am Post subject: Re: %$$ hay rake teeth |
When teeth get bent they will come down on wrong side of stripper bars and will stop the rake. Some times stripper bars get bent also so teeth don't line up. I bought a bunch of rubber mounted teeth from Surplus Center several years ago. They seem to work good and I replace very few teeth |
Back to top |
old Tractor Guru
Posted: Mon Sep 21, 2020 12:14 pm Post subject: Re: %$$ hay rake teeth |
I have a Ford rake with the rubber mount teeth but they break off so fast it would cost a mint to replace them all. One thing I had not noticed that isn't helping is one of the tires is half flat |
Back to top |
old Tractor Guru
Posted: Mon Sep 21, 2020 1:03 pm Post subject: Re: %$$ hay rake teeth |
And now one of the stripper bars has broken about a 1/2 inch from where it bolts to the front angle iron. I think I'll b able to take it off and weld it back together |
Back to top |
Amos Angus Regular
Posted: Mon Sep 21, 2020 4:00 pm Post subject: Re: %$$ hay rake teeth |
Howdy, I use to buy those teeth from pet food supply (TSC), I now buy from New Holland about $2.00 higher each but a few more years out of them |
Back to top |
old Tractor Guru
Posted: Mon Sep 21, 2020 4:04 pm Post subject: Re: %$$ hay rake teeth |
Problem is nearest dealer is 50 plus miles one way |
Back to top |
Shetland Sheepdog Tractor Guru
Posted: Mon Sep 21, 2020 5:31 pm Post subject: Re: %$$ hay rake teeth |
Messicks is your friend!
HTH, Dave |
Back to top |
paul Tractor Guru
Posted: Tue Sep 22, 2020 4:17 am Post subject: Re: %$$ hay rake teeth |
I have a few supply stores around.
Runnings sells good teeth.
TSC sells soft teeth, they bend up like pretzels. Terrible. They aren’t worth bolting on if you get them free.
Mills Fleet Farm are good. They actually have a thinner and thicker versions of NH teeth.
From a dealer are good, cost more.
I hear mail order from Shoup is good teeth, you might want to explore this if you don’t have a good local source.
Paul |
Back to top |
rrlund Tractor Guru
Posted: Tue Sep 22, 2020 4:37 am Post subject: Re: %$$ hay rake teeth |
If farming was easy and fun, everybody would want to do it and I could charge admission. |
Back to top |
MSS3020 Tractor Expert
Joined: 19 Mar 2002 Posts: 1674 Location: Firth, Nebraska
Posted: Tue Sep 22, 2020 7:55 am Post subject: Re: %$$ hay rake teeth |
Hey Old check surplus center in Lincoln, NE out see if they carry your teeth.. |
Back to top |
paul Tractor Guru
Posted: Tue Sep 22, 2020 8:00 am Post subject: Re: %$$ hay rake teeth |
The way I do it, I should charge admission, as a comedy act.....
Sigh.
Paul |
Back to top |
SVcummins Tractor Guru
Posted: Tue Sep 22, 2020 4:36 pm Post subject: Re: %$$ hay rake teeth |
The dealer is actually cheaper than Bomgaars here but he doesnt stock any new holland teeth |
Back to top |
GordoSD Tractor Guru
Joined: 09 Jun 2005 Posts: 12427 Location: Mitchell, SD
Posted: Fri Sep 25, 2020 10:41 am Post subject: Re: %$$ hay rake teeth |
Yes. trying to plow with a rake doesn't work well. If you see a lot of dust when raking your rake is too low. |
Back to top |
