Broken Hi/Low Sherman Lever
8NChris
PostPosted: Sun Sep 27, 2020 1:02 am    Post subject: Broken Hi/Low Sherman Lever Reply to specific post Reply with quote
When an arm breaks does it typically break down inside? Saw this one online that appears the Sherman was removed.
Mike Groom
PostPosted: Sun Sep 27, 2020 5:32 am    Post subject: Re: Broken Hi/Low Sherman Lever Reply to specific post Reply with quote
Sherman was removed and hole was not plugged.
8NChris
PostPosted: Sun Sep 27, 2020 7:43 am    Post subject: Re: Broken Hi/Low Sherman Lever Reply to specific post Reply with quote
CVPost-Mike Groom wrote:
(quoted from post at 06:32:54 09/27/20) Sherman was removed and hole was not plugged.
Wishful thinking. So far the cheap tractors with the auxiliary transmissions are many hundreds or thousands of miles from me.
8NChris
PostPosted: Sun Sep 27, 2020 7:44 am    Post subject: Re: Broken Hi/Low Sherman Lever Reply to specific post Reply with quote
8NChris wrote:
(quoted from post at 08:43:44 09/27/20)
That tractor on Craigslist's was close in the Waco, Texas area.
Maineman
PostPosted: Sun Sep 27, 2020 8:39 am    Post subject: Re: Broken Hi/Low Sherman Lever Reply to specific post Reply with quote
Ill bet you the sherman is in there.
The handle came off.
If someone split the tractor to get the sherman,
They probably would not put it back together!
Joe
Kirk-NJ
PostPosted: Tue Sep 29, 2020 1:41 am    Post subject: Re: Broken Hi/Low Sherman Lever Reply to specific post Reply with quote
The hole was for a sherman combo. Some times a handle can come loose and can come off but unlikely. It could have be taken off. Typically they don't break inside and you should see
the square for the handle close to the end of the hole. If you don't see that it's likely, as Mike said, it was replaced with input shaft and not patched.
Kirk-NJ
PostPosted: Tue Sep 29, 2020 1:55 am    Post subject: Re: Broken Hi/Low Sherman Lever Reply to specific post Reply with quote
I punched in ford in Farm & Garden on CL waco and couldn't find it. than punched in 2n and an F&T overdrive trans came up for $200
8NChris
PostPosted: Tue Sep 29, 2020 5:05 am    Post subject: Re: Broken Hi/Low Sherman Lever Reply to specific post Reply with quote
CVPost-Kirk-NJ wrote:
(quoted from post at 02:55:56 09/29/20) I punched in ford in Farm & Garden on CL waco and couldn't find it. than punched in 2n and an F&T overdrive trans came up for $200
https://dallas.craigslist.org/dal/grd/d/plano-ford-tractors-and-parts-come-see/7203320334.html
Kirk-NJ
PostPosted: Tue Sep 29, 2020 11:23 am    Post subject: Re: Broken Hi/Low Sherman Lever Reply to specific post Reply with quote
If you are close enough go check it out smooth hub
in backround. could be a money maker for you
