Ferguson Moldboard Plow
john in the highlands
PostPosted: Mon Oct 19, 2020 6:04 am    Post subject: Ferguson Moldboard Plow Reply to specific post Reply with quote
On my MF 35 with 14.9 by 24" rear tires, I have a Ferguson 2 furrow plow type 10-AO-40 with a #10H-AO 110 moldboard, and 15 1/2" coulters. The 9" jointers and the moldboard extensions are missing. With the top link (center to center) set at 26" and the right lift link (center to center) at 21 1/2" I plowed a 4" deep by 12" wide furrows. The coulters are 1/2" left of the shares and 1" higher. The plow cross shaft on the left side measures 9 7/8" from the beam to the shoulder. I thought this was a 10" bottom, why am I cutting a 12" wide furrow? Running my right front tire tight to the side of previous left side furrow, my next 2 furrows don't land close enough to the previous plowing. What Am I doing wrong? Thanks, newbie to plowing!
DeltaSteve
PostPosted: Mon Oct 19, 2020 6:31 am    Post subject: Re: Ferguson Moldboard Plow Reply to specific post Reply with quote
Sounds like your tractor wheels are set too wide center to center.
MJ in the UK
PostPosted: Mon Oct 19, 2020 7:03 am    Post subject: Re: Ferguson Moldboard Plow Reply to specific post Reply with quote
Hi John if your plough is set up for 10 inch furrows you need 40inchs between the rear wheels of the tractor so you come right for the finishing furrow. Forget about the cross-shaft LH measurement and do all you measurements from the RH side and try pushing your cross-shaft into the plough frame on the RH side. Also your tyres are to wide for a 10inch plough they need to be 11x28s. MJ.
PostPosted: Mon Oct 19, 2020 4:40 pm    Post subject: Re: Ferguson Moldboard Plow Reply to specific post Reply with quote
I knew my tires would complicate things. I believe there always is way to make things work out. One just has to be creative! Thanks for the suggestions. But why is the furrows 12" wide when it's a 10" bottom plow?
PostPosted: Mon Oct 19, 2020 4:43 pm    Post subject: Re: Ferguson Moldboard Plow Reply to specific post Reply with quote
My rims are dished in, I can't shorten their spacing.
PostPosted: Mon Oct 19, 2020 4:45 pm    Post subject: Re: Ferguson Moldboard Plow Reply to specific post Reply with quote
Thanks, I'll try that
