MF 65 hydraulic stand pipe o-rings
da.bees
PostPosted: Wed Oct 28, 2020 6:34 pm    Post subject: MF 65 hydraulic stand pipe o-rings Reply to specific post Reply with quote
Is it reasonably easy to re-insert pipe after replacing o-rings? If I risk having to drain fluid and pull cover,I'll wait until tractor is back home where I have tools and cherry picker.
DavidP,South Wales
PostPosted: Wed Oct 28, 2020 11:14 pm    Post subject: Re: MF 65 hydraulic stand pipe o-rings Reply to specific post Reply with quote
Hi, it’s easy enough if you only have the original cap on the top. If the pipe comes out with the cap replace the PTFE washers if fitted on the outside of the O rings. Place the pipe back in the cap. Insert the pipe and ensure that you keep the cap square to the cover in both planes. You will feel when it begins to engage and the gap will be square. When it does, give it one thump with your hand and it should go down with a reassuring’clonk’. Be patient until it’s right.
DavidP, South Wales
View user's profile Yahoo Messenger
wjytexas
PostPosted: Thu Oct 29, 2020 3:36 pm    Post subject: Re: MF 65 hydraulic stand pipe o-rings Reply to specific post Reply with quote
and it feels so good when you get it on the first try!
da.bees
PostPosted: Fri Oct 30, 2020 5:44 pm    Post subject: Re: MF 65 hydraulic stand pipe o-rings Reply to specific post Reply with quote
Thanks fellows,I'll have a go at it.
