Shifter
vfleak
PostPosted: Sun Oct 18, 2020 8:40 pm    Post subject: Shifter Reply to specific post Reply with quote
I am replacing the shifter on my Alis Chalmer CA got the old one out but can't get replacement lined uo its the part on the side of tractor with the forks any suggestions ?
Dick L
PostPosted: Mon Oct 19, 2020 2:59 am    Post subject: Re: Shifter Reply to specific post Reply with quote
Take the side plate off. Something is out of place on the side plate. Make sure the forks are snapped in the ident balls. Then line up the gears with the forks.
vfleak
PostPosted: Mon Oct 19, 2020 11:39 am    Post subject: Re: Shifter Reply to specific post Reply with quote
You said Make sure the forks are snapped in the ident balls what are they Thanks for your reply
krumenacker
PostPosted: Mon Oct 19, 2020 4:52 pm    Post subject: Re: Shifter Reply to specific post Reply with quote
vfleak wrote:
(quoted from post at 21:40:15 10/18/20) I am replacing the shifter on my Alis Chalmer CA got the old one out but can't get replacement lined uo its the part on the side of tractor with the forks any suggestions ?
Was it in neutral when you pulled the shifter?
When you pull the side plate, the forks move the gears.
Detente is when they lock into place.
krumenacker
PostPosted: Mon Oct 19, 2020 4:59 pm    Post subject: Re: Shifter Reply to specific post Reply with quote
Apologies, eyes getting bad. Ignore detente comment.
vfleak
PostPosted: Mon Oct 19, 2020 7:28 pm    Post subject: Re: Shifter Reply to specific post Reply with quote
Thanks for you reply . I have tried at least 20 times and still not getting it to line up never one was to quit so I will keep at it
vfleak
PostPosted: Wed Oct 21, 2020 8:30 pm    Post subject: Re: Shifter Reply to specific post Reply with quote
Thanks finally got everything lined up and is working !
vfleak
PostPosted: Wed Oct 21, 2020 8:35 pm    Post subject: Re: Shifter Reply to specific post Reply with quote
Fork for First and Fourth gear were worn to probably half the width had another CA I bought for parts and switched out shifter plate works fine now !
