Author |
Message |
Cliveo New User
Posted: Wed Dec 16, 2020 5:40 pm Post subject: Tea 20 petrol fires up then dies |
Hi Guys, I've put all new fuel tank, fuel bowl and pipe on, cleaned the carbi, I've replaced distributor, coil, leads plugs etc. My problem is it fires up and dies immediately. Any ideas? |
Back to top |
pomester Long Time User
Posted: Wed Dec 16, 2020 6:10 pm Post subject: Re: Tea 20 petrol fires up then dies |
converted to 12v?
Check your wiring to make sure continuity to the coil is maintained after the starter switch is released. If the wiring is original this doesn't apply, but if it's been changed to utilize a solenoid then there may be a misplaced wire to the coil. |
Back to top |
Bruce(OR) Tractor Guru
Posted: Wed Dec 16, 2020 8:05 pm Post subject: Re: Tea 20 petrol fires up then dies |
Voltage not getting to coil in run position.
Bad switch,
Bad wiring,
Mis~wired,
DVOM say's what? |
Back to top |
Cliveo New User
Posted: Wed Dec 16, 2020 8:10 pm Post subject: Re: Tea 20 petrol fires up then dies |
It's not mis-wired, would it be the regulator?
or do you think I should replace the wiring loom? |
Back to top |
John Deere D Tractor Guru
Posted: Wed Dec 16, 2020 8:14 pm Post subject: Re: Tea 20 petrol fires up then dies |
12 Volt original from Factory ?
OR
6 Volt original from Factory ?
OR
some electrical conversion ?
IF you DO a JUMPER to test a start by bypassing the safety system BE SURE TRACTER is NOT in GEAR!
Bob..
Back to top |
Jim L WA Long Time User
Posted: Thu Dec 17, 2020 10:32 am Post subject: Re: Tea 20 petrol fires up then dies |
It's not mis-wired, would it be the regulator? No.
or do you think I should replace the wiring loom? No.
Stop throwing parts at it, that gets expensive. Trouble shoot. What do you see at the coil with a multi meter in the run position. Don't have a multi meter, buy one. They are cheaper than buying unnecessary parts. |
Back to top |
Posted: Thu Dec 17, 2020 1:54 pm Post subject: Re: Tea 20 petrol fires up then dies |
Party Poppir! Your taking the fun out of it. Think of all the other things that could get worked on accidentally also.
Once again.
Voltage ~NOT~ going to coil in ~RUN~ position.
place key in ~RUN~ position, get DVOM and trace back.
You even have diagrams now. Which one is yours? |
Back to top |
