Author |
Message |
Margo Regular
Posted: Sat Dec 19, 2020 7:45 am Post subject: Trailer Hooks |
Saw a post about some bolt on trailer tie down hooks for chains. Can't seem to find post after search. Any help will be appreciated. |
Back to top |
SkipperII Long Time User
Posted: Sat Dec 19, 2020 11:35 am Post subject: Re: Trailer Hooks |
https://www.boltonhooks.com/
If you google, or type in bolt on hooks on your search function, quite a list comes up. |
Back to top |
Margo Regular
Posted: Sun Dec 20, 2020 7:01 am Post subject: Re: Trailer Hooks |
Thanks |
Back to top |
ztrmowers Long Time User
Posted: Wed Dec 30, 2020 7:20 am Post subject: Re: Trailer Hooks |
does your trailer have stake pockets,i use ones that drop in those,you can move around where you need etc |
Back to top |
J Hamilton Tractor Expert
Posted: Wed Dec 30, 2020 9:43 am Post subject: Re: Trailer Hooks |
I looked at some like that in the store and was thinking about getting some. How do you like yours? |
Back to top |
VicS Tractor Guru
Posted: Sun Jan 03, 2021 8:20 pm Post subject: Re: Trailer Hooks |
Our trailer has a stake pocket about every
20" plus a heavy strap welded to the
outside of them from the front to the
back. Drop hook thru stake pocket then
bring hook back up outside pocket and hook
to top of pocket. How would a D ring be
better? Have already took front 2 chains off.
Back to top |
showcrop Tractor Guru
Joined: 13 Dec 2000 Posts: 28931 Location: Chester NH
Posted: Mon Jan 04, 2021 6:11 am Post subject: Re: Trailer Hooks |
Sure you did Vic. Likely story, LOL. |
Back to top |
VicS Tractor Guru
Posted: Mon Jan 04, 2021 1:53 pm Post subject: Re: Trailer Hooks |
Maybe
Back to top |
Chris in SK Long Time User
Joined: 31 Jan 2008 Posts: 844 Location: Saskatchewan
Posted: Tue Jan 05, 2021 6:09 am Post subject: Re: Trailer Hooks |
The drop in D-rings are a little better if you need to run straps back at 45 degrees. The straps just sit better, not rubbing on the edge of the trailer at an angle. With chains that doesn't really matter.....just drop them through the stack pockets as you say. |
Back to top |
Posted: Tue Jan 05, 2021 8:54 am Post subject: Re: Trailer Hooks |
they work fine,gives whole lot more options to tie down |
Back to top |
Posted: Tue Jan 05, 2021 8:58 am Post subject: Re: Trailer Hooks |
i got stopped found it was not legal to have anything on outside of rub rail. all tie downs have to stay inside rub rail |
Back to top |
Posted: Tue Jan 05, 2021 9:51 am Post subject: Re: Trailer Hooks |
CVPost-ztrmowers wrote: | (quoted from post at 09:58:21 01/05/21) i got stopped found it was not legal to have anything on outside of rub rail. all tie downs have to stay inside rub rail |
ZTR, how long ago? That rule was supposed to have been eliminated a few years ago. Go to FMCSA driver's handbook on load securement. You won't find it. |
Back to top |
Posted: Tue Jan 05, 2021 11:15 am Post subject: Re: Trailer Hooks |
2019 got stopped |
Back to top |
DoubleO7 Tractor Guru
Posted: Tue Jan 05, 2021 5:02 pm Post subject: Re: Trailer Hooks |
It is a rub rail, why would you want anything protruding outside of the rub rail to get rubbed off??
Put the hook on the side of the stake pocket. |
Back to top |
VicS Tractor Guru
Posted: Mon Feb 01, 2021 8:42 pm Post subject: Re: Trailer Hooks |
I just watched a video with a Dot officer. You can have hooks and chain or straps on outside of rub rail. And tie to it anyway you want. |
Back to top |
