Author |
Message |
nh8260 Long Time User
Posted: Mon Jan 04, 2021 9:18 pm Post subject: Torque Question |
My service manual came today for the Allis Chalmers 5040 tractor, I have the cylinder head off of it so i can put a new head gasket on it. The manual shows me the correct order to torque the bolts, and they say to do them 82-91 ft-lbs. It does not tell me anything about if i should gradually increase the torque and how many times they need to be torqued
For instance my 555 ford backhoe had the same repair last year and the book said to do 90 ft lbs, then 100, and the last torque was 110. I'm not sure if the AC should be done in steps gradually increasing the torque to get to 91 lbs. or do you torque it one time between 82-91?? |
Back to top |
Bob Bancroft Tractor Guru
Posted: Tue Jan 05, 2021 1:09 am Post subject: Re: Torque Question |
Not a bad idea at all to gradually bring them up. 50-75-90, etc. Won't take but a few more minutes. Does it say to re torque them warm? I would. AC sent a service bulletin that we could over torque heads 10% and avoid doing it again warm. BUT, that was on an AC engine. So we went from torqueing the 301 engines at 150 to 165. |
Back to top |
lfnel Regular
Posted: Tue Jan 05, 2021 4:14 am Post subject: Re: Torque Question |
Usually there's a prescribed order in which to torque the head bolts too. |
Back to top |
Blackhole49 Tractor Expert
Posted: Tue Jan 05, 2021 5:52 am Post subject: Re: Torque Question |
I still can't get my head around this re-torquing issue. None of these engines were re-torqued when new and ran for thousands of hours without a problem. |
Back to top |
Posted: Tue Jan 05, 2021 5:54 am Post subject: Re: Torque Question |
BTW; I was taught to always do it in steps. |
Back to top |
rustred Tractor Guru
Posted: Tue Jan 05, 2021 9:31 am Post subject: Re: Torque Question |
pretty much standard procedure to do a 3 step torque. you NEVER torque one bolt to max. go to the 90 ft. lbs on the third go around. 30,60,90 would be good setting. also these manuals are for mechanic's and you should already know that. they are not teachers. |
Back to top |
Posted: Tue Jan 05, 2021 4:08 pm Post subject: Re: Torque Question |
No, funny thing is not much is said about the cylinder head gasket installation, it gives the order of bolts to be torqued and the 82-91 lbs range and thats basically it. Thanks for the replies |
Back to top |
