MF50 rear axle compatibility
KyleNeron
PostPosted: Sun Jan 10, 2021 4:04 pm    Post subject: MF50 rear axle compatibility Reply to specific post Reply with quote
Forgive me if my terminology is a bit off as I am relatively new to tractors. I have a 1956 MF 50 that a have used hard and gave me no problems until yesterday. Long story short I am in need of a rear axle housing and top cover. Basically everything under the seat. The cast iron housing that bolts to the back of the transmission is cracked beyond repair. What models can I use parts from? What years should I look for? Is there anything I need to be aware of when looking for a parts tractor to repair mine? Thank you for your help.
Dieseltech
PostPosted: Sun Jan 10, 2021 6:19 pm    Post subject: Re: MF50 rear axle compatibility Reply to specific post Reply with quote
Is the diff case and lift cover damaged do to a bad hydraulic pump relief valve?
KyleNeron
PostPosted: Sun Jan 10, 2021 8:04 pm    Post subject: Re: MF50 rear axle compatibility Reply to specific post Reply with quote
Pump and relief valve were replaced less than 6 months ago and gave no problems. The housing was cracked and welded before I ever purchased the tractor and it seems to have just given up. Im not nearly as concerned with cause of failure as I am finding replacement parts.
54FergieTO30
PostPosted: Mon Jan 11, 2021 4:39 am    Post subject: Re: MF50 rear axle compatibility Reply to specific post Reply with quote
KyleNeron wrote:
(quoted from post at 17:04:41 01/10/21) Forgive me if my terminology is a bit off as I am relatively new to tractors. I have a 1956 MF 50 that a have used hard and gave me no problems until yesterday. Long story short I am in need of a rear axle housing and top cover. Basically everything under the seat. The cast iron housing that bolts to the back of the transmission is cracked beyond repair. What models can I use parts from? What years should I look for? Is there anything I need to be aware of when looking for a parts tractor to repair mine? Thank you for your help.
I believe 35's and 50's use the same rear end. Some 35's (those late in production run) had differential lock. Not sure if yours had diff lock. There are casting numbers on the rear end, just look to match the casting number. The axle housings could be moved over to your "new" rear end housing. Hydraulic pumps varied in 35's, so you will want to check to see if those match up.
54FergieTO30
PostPosted: Mon Jan 11, 2021 4:40 am    Post subject: Re: MF50 rear axle compatibility Reply to specific post Reply with quote
Pretty sure TO35, MF35, F40, and MF50 all used the same rear end.
miner09
PostPosted: Mon Jan 11, 2021 7:22 am    Post subject: Re: MF50 rear axle compatibility Reply to specific post Reply with quote
If it's a 56 model then it's not a MF. A MH50 or Ferguson 40. May have
wrong decals which has happens often. Look at serial tag. The early MF50 (58-59-60) will work
but the later may be some difference. Be sure and check before buying.
