Author |
Message |
easter32 New User
Posted: Mon Jan 11, 2021 12:27 pm Post subject: MF 30B No Steering |
I recently purchased a MF 30B industrial L/BH that does not steer. The steering wheel turns freely in both directions. I don't have an operator's manual yet and the shop manual only instructs on Remove, Repair and Replace. No troubleshooting.
Can anyone guide me on the steps to take until I can get an operators manual?
[/code] |
Back to top |
Jim.ME Tractor Guru
Posted: Mon Jan 11, 2021 3:59 pm Post subject: Re: MF 30B No Steering |
What is the whole story? Did it steer when you bought it, but not now? Or did you get a deal because it didn't at time of purchase? Any background on the steering from the previous owner?
Gas or diesel engine? There are some differences it the steering on the two. Mostly just the pump and lines, I believe, but it will be best to know which you have.
Does the power steering pump have oil in it? If it is empty, I believe there may be a filling and air bleeding section in the manual, there is in a couple manuals I have for other tractors.
Is the pump working, making pressure?
I think you may be disappointed if you are expecting the Operator's manual to give you step by step trouble shooting, it is geared more to the normal maintenance an owner/operator would do.
Do you have the actual MF30B service manual or a different one? Trouble shooting is not much in some MF manuals I have. There were often other system fundamental manuals available to dealer mechanics to support the service manuals (which are written for mechanics and usually don't go into DIY level instructions). |
Back to top |
Richard G. Tractor Guru
Joined: 08 Oct 2000 Posts: 13671 Location: Oakway, SC
Posted: Tue Jan 12, 2021 6:07 am Post subject: Re: MF 30B No Steering |
I had a 30 B with a loader.
Seems like I was always working on the power steering.
Had to replace pump.
Had to rebuild the little cylinder in front several times.
Broke the main shaft going down through the front casting and welded it back after grinding it to a point.
Worst steering setup I have ever seen.
Great when they work.
A B---h when they don't. |
Back to top |
easter32 New User
Posted: Tue Jan 12, 2021 10:17 am Post subject: Re: MF 30B No Steering |
the owner has ahlzeimers and the son doesn't know a thing about it except his dad had spent a lot of money on the hydraulics a couple years ago.
No. The steering didn't work when I bought it. The sterring wheel just turns freely. I topped off the main hydraulic fluid and the fluid in the pump.
I'm thinking now that it's probably in the connection between the Steering wheel and what the book calls the steering control unit or steering hand pump under the dash.
Do I need a puller for the steering wheel?
It's a diesel engine. |
Back to top |
MKinON Regular
Posted: Tue Jan 12, 2021 11:24 am Post subject: Re: MF 30B No Steering |
Our 30B has hydraulic steering, no mechanical link. The hydraulic steering is separate from the main hydraulic system with
it's own reservoir in the pump, albeit a small one. Permatran is suggested per the manual. Most likely low oil. Takes a lot
more oil than just fill the pump if the system has bled way down. Start the engine, lift the front wheels off the ground,
remove plug on top of pump reservoir and fill, then cycle wheel back and forth to get air out. If it's really down, you'll
have to refill and repeat till all the air is out. Don't put wheel all the way to one stop or the other or you'll just foam
the fluid as the relief blows. See if that helps. If still no joy, then it could be really badly failed steering cylinder
seals, incorrectly hooked lines, or a problem with the control unit under the wheel, which I think very unlikely unless
rusted out or the system got contaminated, or the top seal (under wheel) blew. Very common is for those pumps to leak all
the system oil into the crankcase through the pump drive shaft seal. If the level get's low and no visible leaks, does the
crankcase oil level rise? To pull the wheel you'll definitely need a puller but it won't come easy. |
Back to top |
easter32 New User
Posted: Tue Jan 12, 2021 12:20 pm Post subject: Re: MF 30B No Steering |
Thanks.
I'll try that next time I go up there. Hopefully it is just drained real low and has air in the system.
I'll keep all of you posted but it will be a few days before I can get back there. |
Back to top |
easter32 New User
Posted: Sun Jan 17, 2021 9:21 am Post subject: Re: MF 30B No Steering |
Went to work on the steering and raised the wheels off the gound. Was putting in fluid, working out the air and was finally getting a response at the steering wheel when the engine just died. No funny noises. Nothing just dead and after several attempts to start it where I could hear the bump of the starter and then a low grade buzz. I felt it best to come back to you guys. Obviously, I am NOT a diesel mechanic!
Any help/guidance would be appreciated. The engine has oil/antifreeze in it. I'm not sure the oil is at the proper level. The previous owner lost the dipstick and was using a screwdriver to cover the hole. Its about a ten inch driver which held beside the engine goes well down into the reservoir and has about an inch of oil on the stick
New stick should be in this Wed. |
Back to top |
MKinON Regular
Posted: Mon Jan 18, 2021 7:58 am Post subject: Re: MF 30B No Steering |
Most likely it ran out of fuel, either completely out, low enough to suck trash into the tank outlet or filters plugged.
Sounds like it may also need a starter or battery, if the engine's not stuck. You could check if it's free by turning the
fan. Won't be easy or turn far, but should move a bit to give an indication. If not stuck, best to change the fuel filter
and clean the cup under tank if one there, put in some fresh fuel after making sure no trash in tank. Be prepared, they can
be a pain to prime fuel system after running out, or servicing. |
Back to top |
